bmr b-body 32mm sway bar? - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 08-02-2004, 11:11 PM
wjarok
anyone used BMR's 32mm b-body sway bar? if so how does it compare to the f-body versions.
post #2 of 5 (permalink) Old 08-04-2004, 09:22 AM
JonRobbinSS
I am using the BMR B-body bar but have not used the F-body bar to make the comparision. I will say that the 32mm B-body bar will rub the insides of the tires at near full deflection.
Jonathan
post #3 of 5 (permalink) Old 08-04-2004, 04:05 PM
wjarok
what size tires are you running?
post #4 of 5 (permalink) Old 08-04-2004, 07:51 PM
OHIO96SS
I had the F-body bar and did not like the angle of it at the bar links.I now have the BMR bar,better fit,close to stock.I have 285/40/17 BFG on Forgeline 9-5 rims.It rubs some at full turn,about the same as with the stock and F-body bars.I like it.
post #5 of 5 (permalink) Old 08-10-2004, 10:29 AM
JonRobbinSS
Sorry about the delay.. I was out for a bit.. I have stock sized conti's on the car
