Extended arms? - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 04-26-2002, 06:03 PM
pimpss96
If I go, better yet, when I go with new extended upper and lower CA, will I have any problems with clearance? I have Eibach springs and Flowmaster cat back. From the looks of things, it may be kind of tight if the wheels are moved back a little. Does anyone else out there have a similar set-up run the new arms?
post #2 of 5 (permalink) Old 04-28-2002, 11:47 AM
ggetshndy
I installed metco arms 3/4 extended. prob i had was interfearance with exhaust pipes that go over the diff.took a trip to muffler shop.
good luck.
post #3 of 5 (permalink) Old 04-30-2002, 03:25 PM
MOORESS
I did my bmr extended this past sunday no problem's.
post #4 of 5 (permalink) Old 04-30-2002, 03:44 PM
pimpss96
you did it with no probs, but is your car on springs? I see you have an exhaust, but it seems like the springs and CA might cause a problem.
post #5 of 5 (permalink) Old 04-30-2002, 09:03 PM
tonyss96dcm
When i was running Eibach springs and the Hooker cat-back exhaust i would have trouble with the pipes hitting the frame and axle. Moving the pipes would fix this. But when i put on the BMRs and the HO rear bar the exhaust pipes would be smashed between the rear bar and the gastank. So i dumped the exhaust right after the mufflers.
Tony
