noise comming from the rear drivers side - Chevy Impala SS Forum
post #1 of 37 (permalink) Old 07-14-2004, 03:17 PM
Eric 96SS
there's a squicking noise comming from the rear drivers side wheel. It only makes it when the wheel is spining as soon as I hit the breaks it stops. Anybody know what it might be?
post #2 of 37 (permalink) Old 07-14-2004, 03:49 PM
Damage
Probably your brake pads. Especially if the noise disappears when you step on the brakes.
Does it speed up when you speed up and visa-versa?
Peace.
Damage
post #3 of 37 (permalink) Old 07-16-2004, 09:44 AM
Eric 96SS
yes.. I will change pads this weekend.what else could it be if noise doesn't disappears?
post #4 of 37 (permalink) Old 07-16-2004, 01:20 PM
LarryCigar
Please describe noise better.
Don't know what 'squicking' means?
Sometimes a bad Axel Bearing related noise will disappear/lessen when you apply brakes.
post #5 of 37 (permalink) Old 07-19-2004, 01:04 PM
Eric 96SS
OK..did my rear brake pads this weekend and noise still there. If I speed up the squicking noise is faster slows down when I reduce the speed down, but goes away when I apply brakes....need help the noise is really irritating.
post #6 of 37 (permalink) Old 07-19-2004, 03:24 PM
LarryCigar
Talking
I'll guess "SQUEAKING" Axel Bearing. [img]graemlins/4.gif[/img] If AB is toast, you'll need to replace Axel Shaft as well!
Have you installed improved Differential Cover Gasket[it improves rear lube getting to Axel Bearings]?
If not, you'll get a chance now, if Axel Bearing diagnosis is correct.
Fel-Pro PN RDS55028-1 or GM PN 26066456
ADD: Could also be front or rear Driveshaft Universal Joint.
post #7 of 37 (permalink) Old 07-19-2004, 05:20 PM
Eric 96SS
Yes squeaking....Sorry. MAN, and I had the fluid change on my rear end about 4 months ago. Thaks for your help Larry
post #8 of 37 (permalink) Old 07-19-2004, 05:47 PM
vandal835
I hope my squeaking is from the front! Ill see when I replace bearings and pads this week.
post #9 of 37 (permalink) Old 07-20-2004, 01:44 AM
LarryCigar
You better spell it right! [img]graemlins/.gif[/img] [img]graemlins/.gif[/img]
post #10 of 37 (permalink) Old 07-20-2004, 01:53 AM
LarryCigar
Lightbulb
Eric, suggestion; you or Gearhead friend remove rear driver side wheel[that is the one you think sqeaking is coming from, right?], and while grasping Rotor hat, try & move up & down to check play between Bearing and Axel Race. Should be minimal.
Also check back of tire/rim for signs of gear lube.
Once a Bearing wears enough, the Axel Seal usually fails also.
