9c1 swaybars on Civilian Caprice - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 10-07-2003, 06:40 AM
falping
Hi Guys.
I have a 91 civilian, and I am upgrading the suspension. I have right now swayarms both in the back and front.
Would it be any better to buy 9c1 sway bars? I have been offered sway bars here in sweden for 260$, but I suspect that they are the same size as I have.
Anybody knows what dimension the sway bars have, both front and rear on 9c1?
post #2 of 4 (permalink) Old 10-07-2003, 07:25 AM
capriceutah
They should be a bit thicker! And it will help
I added the rear control arms from a 96 imp.
Check this thread:
https://www.impalassforum.com/cgi-bin...=000059#000000
post #3 of 4 (permalink) Old 10-07-2003, 03:05 PM
falping
capriceutah, thanks for the update.
Well, according to this message the stock 9C1 front bar is 30mm, the rear is 25mm.
I have F41 option on my Caprice. It seems to be 30 mm front bar, and the rear bar is 24 mm.
Hmm, not much of a idéa then to pay 300$ when there is that little difference.
I save my bucks to HA swaybar instead.
Says Krister
post #4 of 4 (permalink) Old 10-07-2003, 05:26 PM
96DCMSS
I know this isn't my thread, but why start a new one... When I changed my frame on my impy, I used a frame from a 95 civilian caprice(LT1). I retained the caprice FRONT swaybar, since the one on the impy was bent....My question is, is it the same bar? They are visibly the same, but I haven't measured them. TIA, Jason.
