ES End-link sizes compared... - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 03-17-2004, 07:06 PM
rkeeler33
Quick question here...
I wanted to buy new ES end-links and I did purchase these from Troy at the Superstore, however, I received the ES 9.118 size and everyone speaks about the 9.8123.
</font>
  • Which are the correct ones?</font>
  • Will the 9.8118s work?</font>
  • If so, what is the difference?</font>
Thanks,
Rob
post #2 of 8 (permalink) Old 03-18-2004, 10:06 AM
Kevin Overall
You can buy the proper end links from AutoZone, or at least I did. Just carry one of your stock bolts in to AutoZone (assuming your car is not lowered, if so take away in inches how much your front is lowered from the stock bolt) and match the bolt and spacer up to what is on the shelf at autozone.
post #3 of 8 (permalink) Old 03-19-2004, 09:48 PM
rkeeler33
I talked with the SSuperstore today and Jason there told me that Troy decided to go away from the ES 9.8123 End-links because they are too short. They are only 2 1/4". He went on to say that this is the reason why they went to the ES 9.8118 because they are 2 7/8".
Can anyone provide me with a little feedback here...thanks!
-Rob
post #4 of 8 (permalink) Old 03-20-2004, 12:01 AM
LarryCigar
It was difficult to get the 9.8123's on, but they're on there about 6 months now & are ok.
Whatever you go with, tighten at ride height, only until Bushings start to bulge.
DO NOT overtighten!
post #5 of 8 (permalink) Old 03-20-2004, 12:38 AM
rkeeler33
So what do you think...try the 9.8118s or exchange them and get the 9.8123s?
post #6 of 8 (permalink) Old 03-22-2004, 12:09 AM
rkeeler33
Can anyone help me out here?
post #7 of 8 (permalink) Old 03-22-2004, 01:07 AM
Kevin Overall
The difference in sleeve length is just a little over 1/2 of an inch, I would go ahead and put the 2 7/8 on and if they are a little snug you can shorten them a little, 1/2 of an inch should be well within the range of the threads on the bolt.......
post #8 of 8 (permalink) Old 03-22-2004, 07:52 AM
rkeeler33
Thanks Kevin, I'll be trying these this weekend!
Thanks again,
Rob
