How to get ride of bump steer - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 01-31-2002, 06:24 AM
CaddySS
What is the best way to correct mild bump steer? Thanks.
post #2 of 4 (permalink) Old 01-31-2002, 03:10 PM
It won't eliminate it, but it helps considerably....
Get solid tierod adjusters. I have the Global West ones, but the ones from Hotchkis or Baer will work just as well.
About $50 for the parts, and you'll need to redo your front end alignment afterwards.
Also check the rest of the front end for any worn components, and replace as necessary.
post #3 of 4 (permalink) Old 01-31-2002, 03:25 PM
CaddySS
Thanks Ed,
I read an artical on the Bear units a while back and was thinking about them. Replacing the steering parts will probably need to be done as well. She's about to roll 100,000 miles. Thanks again.
post #4 of 4 (permalink) Old 01-31-2002, 07:47 PM
bryante
Bump steer is caused by poor suspension geometry. It's pretty easy to see it in action - just jack up the front end of the car and watch the toe angle change.
The solution would be to re-work the suspension geometry. I think that fixing the bump steer problem would be easier than fixing the camber control problem, but it's still not a simple task - most likely, it'd involve some work on the center link at the very least, and maybe some massaging of the knuckles.
