Rear squeaking ? - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 09-27-2004, 06:50 PM
95ChebySS
I have been trying to locate a high pitched squeak from my driver's side rear quarter when I hit a bump.Shocks are tight ,doors too,and all usual reasons for this knd of noise I have checked.Car has 37k and is all orig.
It's very difficult to tell if the noise is internal or external.If anyone of you guys can offer some ideas please feel free to chime in , it will be appreciated.
post #2 of 8 (permalink) Old 09-27-2004, 08:15 PM
buffman
Check to see if your exhaust is hitting the upper control arm or perhaps if the UCA itself is shot..
Matt
post #3 of 8 (permalink) Old 09-27-2004, 10:11 PM
Imalabil
Might be your e-brake, they are annoying.
Bill
post #4 of 8 (permalink) Old 09-28-2004, 07:55 AM
HEADSICK
Try lubricating the control arm bushings. My car was making a godawful squeek when I hit bumps too, so I greased all the control arm bushings and it stopped. HTH
post #5 of 8 (permalink) Old 10-05-2004, 06:46 PM
wstaten
I have some squeaking coming from the rear also but it happens all the time. If I push my car on the side it starts squeaking. I looked under the car and their are some metal pieces around the fuel tank and when I move it a little it squeaks. Does anyone know what the metal pieces are.
post #6 of 8 (permalink) Old 10-08-2004, 07:34 AM
caprice96
I have a squeak when i go over bumps too i dont knwo if its from the rear tho
post #7 of 8 (permalink) Old 10-08-2004, 10:42 AM
mrthump77
I think they are usually mistaken for heat shields. If I'm not mistaken, I believe they protect the tank from things flying up there and damaging/puncturing the tank.
post #8 of 8 (permalink) Old 10-08-2004, 01:22 PM
sokoolss
I have the squeaks as well. I took some WD40 and sprayed the exhaust hangers with it the first time and they went away. What was happening in my car was the hangers were squeaking and echoing through the exhaust pipes. Now I'm going to spray the LCA's and bushings.
Good luck
-Sokol
