Tight/firm front suspension!! - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 03-15-2004, 10:16 PM
ruf_sport
Was looking for a nice tight, yet firm suspension for the front of my SS.
NE idea's? Was looking into the Moog springs or maybe the H&R. BMR 2 gen. F-body swaybar... Bushings from Dal. Hotchkis tie rod sleeves..
What else would work?
Thanks
post #2 of 7 (permalink) Old 03-15-2004, 10:21 PM
Rustic
That's a very broad question.... all the parts you mention might work... the issue is putting together a package that you are happy with.
post #3 of 7 (permalink) Old 03-15-2004, 10:28 PM
ruf_sport
I just wanted a slight drop, maybe an inch to an inch 1/2..I'm going to get the BMR swaybar, already have the tie rod sleeves. Just not to sure on the springs!! I've heard mixed reviews on the H&R's.
post #4 of 7 (permalink) Old 03-15-2004, 11:24 PM
boedean
The H&R's are firm but quite low. The Hotchkis springs might be the stance you're looking for. If you want very firm but not necessarily lower in the front, how about the Global West springs? Read up on the Vogtland spring set as well. They sound like slightly firmer with a slight drop. Are you looking for rear springs too-or just fronts?
Jeff
post #5 of 7 (permalink) Old 03-16-2004, 08:38 PM
Spartus
You could also install a set of the ZQ8 bump stops in the front... My car is riding right on them, as they are designed to be. Any impact will be absorbed partially by these new bumpstops. These, along with my Bilstiens, and Vogtlands should be an interesting ride.
post #6 of 7 (permalink) Old 03-16-2004, 09:15 PM
B-Body Builder
Just got my ZQ8 bump stops from Dal today! Got a set of Hotchkis Springs also that are going in with these in the near future! I'm using Edelbrock IAS Shocks though and Love them! Edelbrock has finally worked the bugs (And leaking problem they had in the past) out of them.
post #7 of 7 (permalink) Old 03-16-2004, 10:09 PM
ruf_sport
Thanks guys for your input and suggestions..I'll call and speak to Dal.
