PS Pump Install Hints - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 04-05-2002, 07:43 PM
smassie88
Anyone have any power steering pump install hints/tricks. Will be attmepting mine either Saturday or Sunday. Looks like a long learning process. Thanx all.
post #2 of 3 (permalink) Old 04-09-2002, 05:37 AM
stomper
Get a drain pan and take the lines loose down at the steering box to drain the fluid.If not you will have fluid on your a/c comp. and it will take paint/finish off just about anything.
post #3 of 3 (permalink) Old 04-09-2002, 05:53 AM
stomper
Also it takes a special puller to remove the pulley to get the bracket off behind it and to put the pulley back on the new one.I took my pump to the dealer had had them to remove the pulley.Unbolt the cover part first,that makes it a little easier to get to the lines behind it.One screws in and the other has the spring clamp from hell on it Put a regular clamp back on.
