Sway Bar Mount - Stripped Bolt Fix - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 03-21-2004, 05:37 PM
B-Body Builder
Thumbs up
Thought I'd share the fix I had to do when installing new sway bar mounts and bolts on the 95 Caprice. I Used the Upgraded GM sway bar mount Bolts (GM part#15959689) when Installing the new ES Poly mounts and bushings.. All went well taking the old bolts out UNTIL I got to the drivers side rear bolt ! Started removing it and metal shavings started coming out with it . Yep, Hole was nearly stripped and wouldn't Re-Torque to 24Ft Lbs. After removing the new bolt, The thread locker on it was history! (Why I Used Loc-Tite). The other 3 Mounting holes were fine. My solution and fix for this is detailed here:
The tools I Used for this fix are: (1) a Retracktable Magnet stick (2) Large flat Head Screwdriver (3)Hardened Flare Nut W/Nylon packing inside (4)Torque Wrench, 10mm Socket and Extensions and a small piece of metal coat hanger, Loc-Tite and Flashlight.
TOOLS USED FOR THE REPAIR
NEW NUT AND BOLT
What I Basically did was apply some Loc-Tite to the new bolt, Then Run the new bolt thru what was left of the stripped hole and Mount, just enough to barely stick up a 1/16" inside the frame. (Used a Flashlight to check the depth thru the outside frame hole). Then I Took the retracktable magnet and new Nut and carefully guided it thru the frame hole, and close to the bolt sticking up thru the frame, Then released the nut from the magnet.
Removed the Magnet Stick, Then stuck the piece of coat hanger thru the hole and guided the nut onto the bolt while using the flashlight to see it. Using a 3/8 Ratchet, I Slowly turned the Bolt until it threaded into the nut a few turns (This took a few attempts to achieve), Then stuck the large Flat head screwdriver thru the framehole and Logged it between a Flat side of the nut and the lower Front Steering gear box Bolt as shown in this pic (It fit nice and snug between them)
Slowly turned the bolt with the 3/8 Ratchet while prying up on the screwdriver until the nut was flush and the bolt had gotten fairly tight. Set the torque wrench for 24Ft Lbs and Finished tighting it up! BTW, You can forget trying to fit a 15mm Wrench or Crows foot Etc.. thru the Framehole! It Ain't gonna happen and reach the nut, I Tried this 1st! Of course I Couldn't have gotten a stripped hole on the Passenger side (Where you can get easy access to the holes) and I Dont know, Or want to find out how to repair the drivers side front hole [img]graemlins/4.gif[/img] Hope this procedure helps some else out if it ever happens to them! It worked pretty easy for me but I Wont say it wasn't a PITA At times but I Did manage to pull it off by Myself! I'm sure a helper would make it easier.
post #2 of 13 (permalink) Old 03-21-2004, 06:05 PM
Navy Lifer
Mike, here's more:
stripped frame threads & weld nut info
studs through frame "fix" & picture
nutserts/sway bar bracket
front sway bar removal
[ 02-12-2007, 10:40 PM: Message edited by: Navy Lifer ]
post #3 of 13 (permalink) Old 03-21-2004, 06:13 PM
B-Body Builder
Hi Bill, I See I'm not the only one that encountered this senario in the past! I have access to those type of weld nuts "As GM Calls them" at work (GM) But I'm off for a few days so I Just Had to "Improvised" This fix! However, Now I Know what to do should Any more show up Stripped! Alot of good options in those posts. BTW Bill, Are the mounting holes known to strip out on their own during normal Daily driving use or does this sort of thing usually happen just when you remove/replace the bolts? ......Thanks for the links Bill!
post #4 of 13 (permalink) Old 03-22-2004, 01:40 PM
Navy Lifer
Mike,
I think the collective experience of the Forum suggests that thread failure most typically happens during removal or installation, since the fasteners are said to be of the "one-time use" (prevailing torque?) variety. I can imagine that on cars with greater moisture/salt corrosion exposure, the threads in the frame are more prone to let go in a "dynamic" situation. The larger bars frequently used probably contribute to the problem, since more force gets applied to the clamping points--and in the process of changing the bar or bushings, I'd wager that the fasteners are frequently over-tightened, damaging the threads on the fastener and/or the frame.
From your own experience, assembly-line efficiency can often dictate use of special methods/parts that don't stand up to any amount of R&R.
The way GM did this particular setup probably saved a couple of repetitive motions or assembly steps, or reduced cost, which the bean-counters were always interested in. Many alternatives to what GM did are available, and we've probably covered most of the most practical ideas in the discussion(s) I linked for you.
post #5 of 13 (permalink) Old 03-22-2004, 02:42 PM
LarryCigar
Mike, nice write up & pix. [img]graemlins/5.gif[/img]
I got lucky when I did mine, both Pass. Side Bolts needed Nutting[is that a word? [img]graemlins/0.gif[/img] ]. Very Easy.
Ummm, Retractable Magnet Tool[where's my list?]
post #6 of 13 (permalink) Old 03-22-2004, 04:47 PM
B-Body Builder
Boy you said a mouthfull there Bill and every word of it's TRUE! Back in 95, It stands to reason that many of these bolts were quit possibly "Over-Torqued" on the Assy line Also! We didn't have Nearly the Number the Precise tools set to the proper torque specs as we do now in GM. The way things are setup now, If your Gun does not shoot the proper Torque on a given Assy process, a Siren goes off above your Head and Your tool has a red Light indicator on it. If it's not Torqued properly in 30 Secs, The Line stops! The General Has slowly Gotten things together in this Aspect. Our whole plant is now on this Setup. There are 20 "Torque Monitors" (People) in the Plant that their sole job is to go around the Plant each day in their designated area with some Pretty High $$$ Equipment and check all the Tools/Guns for proper torque specs, Right down to the Battery powered 10nm Small nuts and bolts. MVSS Items are Really scrutinized! Even cars needing "Repairs" are done with a Torque wrench that's connected to a "Brown/Sharpe" hand held torque monitor and cant be considered an "Approved Repair" until the torque data from the repair is uploaded into
the Plants Mainframe monitoring System.
post #7 of 13 (permalink) Old 03-22-2004, 04:52 PM
B-Body Builder
Thanks Larry! The Retractable Magnet I Have is Spring loaded setup, Once you get what you need to where it's going, Release the Thumb Spring and It lets go. Great also for guiding Bolts Etc.. To those hard to reach area's! BTW," both Pass Side Bolts needed Nutting, You LUCKY Sh$t! [img]tongue.gif[/img]
post #8 of 13 (permalink) Old 03-22-2004, 06:21 PM
LarryCigar
If I'm so lucky, why can't I hit the F__kin Lotto.
I don't wanna work no more! [img]graemlins/4.gif[/img]
post #9 of 13 (permalink) Old 03-22-2004, 08:22 PM
Terry McManmon
And who makes that nifty little bugger? I want one.
post #10 of 13 (permalink) Old 03-22-2004, 08:57 PM
Erik
Me too. Nice job on the write-up, BTW.
