Sway bar specs? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 03-26-2004, 08:36 AM
DPSE
Anyone have the article that mueller put out about the different stiffness's? I am looking for a setup for my car with hotchkis spring and stiff bilsteins and am looking for an swaybar setup....looking into hotchkis or Hellwig/HO(BMR) or full HO(HO) setup.
looking to compare the stiffness's...thanks in advance
post #2 of 4 (permalink) Old 03-26-2004, 09:36 AM
Knightshade
post #3 of 4 (permalink) Old 03-26-2004, 09:49 AM
DPSE
wasn't the hellwog on the original article that was on B-body.net?
post #4 of 4 (permalink) Old 03-26-2004, 09:55 AM
scot august
Since the article was written, Quickor Suspension developed an offset front sway bar that is considerably stiffer as it is both shorter and with fewer bends, than any same diameter OEM configured bar .They will supply it in any diameter from 5/8 of an inch to 1 1/2. Offset also avoids tire rubbing at full lock and any interference with after market or factory front wheels.5/8 to 1 1/2 inch rear bars are also available.
