Where to find a GM front coilspring compressor - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 03-25-2002, 10:43 PM
u-low-fo
hey guys, am in the process of lowering my '94 wagon and need above mentioned spring compressor, tryin to avoid eating a sprung spring. would've thought the tool was readily available, local tool crib says $150 and one week to order, kinda wanted to work on it over the long weekend. have tried local tool rental places, and carparts, ie autozone/advanced etc, nada. any info is much appreciated. thanks.
post #2 of 7 (permalink) Old 03-26-2002, 12:57 AM
I rented one from Kragen's on the last swap, cost $10 to rent as long as I needed it.
That said.....you can easily get out stock springs without a compressor, and EASILY get the lowering ones in without one. The only reason I needed one on that job was to get the springs back IN.....and even then, didn't need it by much.
So, for your job you don't need the compressor. Just disconnect the balljoint with a jack under the A-arm, and SLOWLY lower it out of there. Once it's completely down, you'll be able to (relatively) easily get the spring out. And the shorter lowering spring will be a piece of cake in comparison.
post #3 of 7 (permalink) Old 03-26-2002, 07:02 AM
PRoz
I would recommemd that you loop a chain through the spring and around the frame to hold the spring in place if you have never done it this way before. If the jack slips when lowering the a-arm the spring could come out if it isn't contained.
post #4 of 7 (permalink) Old 03-26-2002, 08:27 AM
Baatfam
AutoZone has one in their FREE rental program that I used.
And I'm very glad I did. The stock Caprice spring would not have come out with out it, not safely anyway.
Careful anyway, still had one slip and I caried a bruise under my finger nail for months. Boy did that hurt
Later,
post #5 of 7 (permalink) Old 03-26-2002, 10:30 AM
u-low-fo
thanks for the help guys.
post #6 of 7 (permalink) Old 03-28-2002, 10:17 AM
sstripes96
Bought mine at NAPA for $54.
post #7 of 7 (permalink) Old 03-28-2002, 03:13 PM
bryante
I got my spring compressor for $60 from the local Parts Plus. Probably could have done the job without it, but it seemed easier than catching a spring with my forehead.
