HD12 Front Brake Kit - Page 3 - Chevy Impala SS Forum
post #21 of 41 (permalink) Old 11-25-2013, 09:06 AM
Lance's Avatar
Thumbs up
Bill -
Money sent.
Thanks for getting this kit together and all of your help.
Hubs, calipers, and pads are next.
ISSCA #2305
ECIRS #222
WAIL
95 9C1:
12.19 @ 111, ESE 357, LE2 heads, LE 224/230
12.86 @ 105, Reman 355, Z28 heads, CC 502, CPT 3, Edge 3400, 4.10, PCM4Less
96 SS:
11.74 @ 117, ERE 383, LE2 heads, AI 234/242, CPT 3, Yank 3600, 3.73, PCM4Less
12.28 @ 110, Golen 383, LE2 heads, CC 503, CPT 3, Yank 3600, 3.73, PCM4Less
13.07 @ 101, Rebuilt LT1, LE2 heads, Crane 227, CPT 3, Yank 3600, 3.73, PCM4Less
14.11 @ 95, Stock LT1, Edge 3000, 3.73, PCM4Less
Lance is offline
post #22 of 41 (permalink) Old 11-25-2013, 09:08 AM
Lance's Avatar
I know Bill has provided a thorough thread with direct links about his kit, but here are pixs of the KORE3 hubs that you need to order separately:
NAPA calipers:
Lance is offline
post #23 of 41 (permalink) Old 11-25-2013, 11:42 AM
MadMav's Avatar
Your Wilwood links in the first post are broke Bill. FYI.
Mav
'95 DGGM
'13 Charger SRT8
MadMav is offline
post #24 of 41 (permalink) Old 11-25-2013, 12:17 PM
Lance's Avatar
Question studs/
Bill, I went with the M12 press in studs.
M12x1.5 is the standard size stud correct?
KORE3 will press the studs in correct?
Sorry, I guess I should have ask the guy at KORE3 when I ordered.
ISSCA #2305
ECIRS #222
WAIL
95 9C1:
96 SS:
Lance is offline
post #25 of 41 (permalink) Old 11-27-2013, 12:43 AM Thread Starter
Navy Lifer's Avatar
Originally Posted by Lance View Post
....here are pixs of the KORE3 hubs that you need to order separately:
Understand that the final product is black anodized--this is a fairly old photo--screw-in 1/2" studs, and the hub snout configuration has been modified to add more clearance at the outer end to provide room for wheel center caps that snap into the wheel--several aftermarket wheels could not run caps with the older design hub. Tone rings are not included.
M12x1.5 is correct and the studs are already pressed in (default is ARP)
Mav, I hear you--the thread is so old that the mod & admin don't allow editing.
Here's a current Wilwood link, though it may not stay good for very long, as Wilwood seems to re-shuffle info on a regular basis:
http://wilwood.com/Calipers/CaliperL...0Dual%20Piston
correct for HD12: http://wilwood.com/Calipers/CaliperP...emno=120-10936
2-caliper kit with pads:
http://wilwood.com/BrakeKits/BrakeKi...Caliper%20Kits
correct for HD12: http://wilwood.com/BrakeKits/BrakeKi...emno=140-11290
Bill Harper
ISSCA #127
[email protected]
Navy Lifer is offline
post #26 of 41 (permalink) Old 11-27-2013, 12:46 AM Thread Starter
Navy Lifer's Avatar
HD12 - Black Friday special pricing - 2013
Black Friday special, good from Nov 29th to Dec 6th, 2013
Standard - $472.50 (normally $525) - 10% discount
With cryo plain rotors - $510 (normally $575) - 11.3% discount
With cryo slotted rotors - $525 (normally $600) - 12.5% discount
Please contact me directly via PM or e-mail for full details!
Bill Harper
ISSCA #127
[email protected]
post #27 of 41 (permalink) Old 11-27-2013, 08:44 AM
91ss's Avatar
Bill, did you ever compare these hubs to Astro rotor solution "hubs".
91ss is offline
post #28 of 41 (permalink) Old 11-27-2013, 11:17 AM Thread Starter
Navy Lifer's Avatar
Over the years, as I was looking at how to accomplish what eventually became HD12, I did essentially what was to become the Astro setup. I never created parts to install, since I decided it wasn't a viable approach. Some time later, the KORE3 hub came into existence, and the final HD12 configuration was always based on that hub.
If I get what you're thinking or wondering, the answer is that HD12 is not compatible with cut-down stock rotors as hubs without some compromises that I am unwilling to make.
That said, I can't stop someone from using HD12 rotors and then coming up with their own hub adaptation. Enough time, material, and a good machinist can accomplish alot.....but I'm satisfied with the HD12 setup as I developed it--I do understand the cost issue, but, with brakes being a critical vehicle system, and the fact that I can't control what someone else does if the KORE3 hub isn't used, it leaves me exposed if I was to endorse an alternate hub package for HD12 that is home-grown, thus I would not be able to know if it will work without issues.
The main criteria includes having the ability to control the critical fit/clearance between the hub OD and hat ID, lateral position of the rotor in relation to knuckle and caliper, and to prevent the loss of hub register with the wheel--the HD12/KORE3 hub combination addresses all issues quite satisfactorily.
Bill Harper
ISSCA #127
[email protected]
post #29 of 41 (permalink) Old 11-27-2013, 12:06 PM
91ss's Avatar
Yep, you got what I was getting at and I get what you're saying. Just felt the door was open to the question as the KORE hub is priced out separately.
91ss is offline
post #30 of 41 (permalink) Old 12-09-2013, 08:19 AM
Lance's Avatar
Thumbs up
Installed by Nab at EFI Performance in MD.
Look great and are heavy duty.
Bill thanks for a great product and a great purchasing experience.
HD12 rotors, KORE3 billet hubs, billet dust caps, Caddy HD calipers (NAPA reman), and Hawk HPS pads:
ISSCA #2305
ECIRS #222
WAIL
95 9C1:
96 SS:
Lance is offline
