LT1 stroker standard bore (377) - Chevy Impala SS Forum
 2Likes
post #1 of 13 (permalink) Old 05-16-2019, 09:22 PM Thread Starter
JZ9C1LT1's Avatar
Been looking on the net for 377 stroker kit but only see 383 kits. Anyone make kits with the stock bore or must it be pieced together?
There is hardly any wear, even measured it. Only about .002 wear top to bottom.
96 9C1 LT1 with all the bolt on crap (Gone 1/08 to 9C1 heaven aka junkyard!)
95 9C1 LT1 New toy as of 6/09 (this one is now heading same direction as the 96)
95 9C1 LT1 The new black mariah! SOLD
95 9C1 LT1 Will be my whenever I get it done project!
94 Caprice
04 GTO SOLD
Originally Posted by BewbZowt(+ Y +)
Here's how it works: If I can see them, they are real.
JZ9C1LT1 is offline
post #2 of 13 (permalink) Old 05-16-2019, 10:59 PM
Pistons and/or rods will be different because of the longer stroke to maintain compression ratio.
Fred Kiehl is online now
post #3 of 13 (permalink) Old 05-17-2019, 01:13 PM
^^, yep
Op, I would go 6" rod and a shorter piston. I have SRP pistons but mine are .030 over as I did bore .030 with the stroker crank to get the 383
post #4 of 13 (permalink) Old 05-18-2019, 09:10 PM Thread Starter
JZ9C1LT1's Avatar
The problem is every kit I see is for a .030 overbore. I don't want to waste money boring it oversize if it doesn't need it. This sucks.
Update: Just saw an old post the Nab posted that has Summit selling a kit. Happy, happy!
94 Caprice
04 GTO SOLD
JZ9C1LT1 is offline
post #5 of 13 (permalink) Old 05-18-2019, 09:21 PM
It will cost you just about as much to just stroke it. I do not know how readily available the correct pistons and rods are, and if they will be a premium price, whereas the pistons and rods are readily available for the 383 conversion. You need to check the availability of the parts before making a decision.
post #6 of 13 (permalink) Old 05-19-2019, 02:07 AM
4x4high's Avatar
Now tell us how out of round the cylinders are.
1996 DGGM Impala SS
4x4high is offline
post #7 of 13 (permalink) Old 05-19-2019, 06:44 PM Thread Starter
JZ9C1LT1's Avatar
4x4high;
I checked the bores 90 degree apart and had a total of .002 on the bores.
Fred;
Summit and Jegs has the complete 377 stroker kit for just over 1K (piston, rods, and crank).
94 Caprice
04 GTO SOLD
JZ9C1LT1 is offline
post #8 of 13 (permalink) Old 05-21-2019, 12:13 PM
KW Baraka's Avatar
Unless you're on a really on a tight budget, I'd say go ahead and bore it over .030".
Should cost you about $250 or so.
KW
1995 DCM SS, LS3, V-max 90mm TB, Lingenfelter GT1-1 cam, Headman 1 7/8 LT Headers, 2 1/2" cat-back, 3200 Circle-D TC, 3.73 gears -- 493HP/434TQ @ the wheels (Daily Driver)
KW Baraka is offline
post #9 of 13 (permalink) Old 05-21-2019, 01:43 PM
^^^, yep OP
You are buying the crank, rods and pistons so the only extra cost is machine work to go .030 over (IMHO this would REALLY clean up cyl walls also) and you get more C.I. which always= more HP/TQ
I would do the .030 over bore and line hone and get new cam bearings installed. You are deep into a rebuild..go the distance
I hope you are not getting a cast stroker crank.....I am a member of the 2 piece cast stroker crank club (Eagle)….go forged crank and even still stay away from Eagle IMHO.
post #10 of 13 (permalink) Old 05-21-2019, 03:32 PM
juniorwatson's Avatar
I agree with what everyone else has written. You're putting XX amount into the entire build, at this point, what's an additional ~$240 (Approx $30 a hole for bore & hone) to ensure you have a killer build?
I can understand doing things on a budget, but this is such a minor expense, it makes just good sense in engine building for the long term.
juniorwatson is offline
Similar Threads
WTB: standard bore LT1 pistons tayto Parts for sale/wanted 0 06-08-2018 11:25 AM
377 stroker eshaw301 Engine Performance 67 06-10-2016 12:14 AM
Little Home Made 377 Stroker BarryG Engine Performance 110 05-14-2012 06:07 PM
throttle body bore blade to bore clearance? The Caretaker Engine Performance 1 05-19-2011 06:19 PM
377 stroker ? GreenHornet Engine Performance 12 11-28-2008 10:38 AM
