6.0 4l80 swap - Chevy Impala SS Forum
post #1 of 17 (permalink) Old 05-22-2019, 09:58 AM Thread Starter
6.0 4l80 swap
I am sure it is on here someplace but in my searching i have not been able to find it. I have a 94 Caprice with a worked lt1 that i am done with. Bought a 2003 Chevy Express the other day and would like to swap the motor and tranny into the Caprice. I assumed someone has done this build before and might be able to prevent me from reinventing the wheel. The plan right now is KDS motor Mounts, LS1 Oil pan and a new tranny crossmember so i can get the drive train bolted in. Then i hope to do the rest of the work over the winter to have the car ready for next April when it is 20 years of ownership.
Things i have questions one.
What crossmember works with the KDS motor mounts?
Best oil pan to use on a budget?
OBD1 LT1 to OBD2 LS what issues?
Anything special to put in the 4l80?
Not trying to be a jerk but if you have comments on why not just leave the lt1 or the 4l60 it not what i want anymore plain and simple. Really just looking to not waste any more money then i have to on this swap.
If i posted in the wrong area i am sorry.
Thank You for any help.
cor1987 is offline
post #2 of 17 (permalink) Old 05-22-2019, 10:44 AM
Blue Wail's Avatar
Truck engine needs a cam and head swap or it won't be any more powerful than LT1.
TrickFlow has some cams less than $300 for LS. Get some 5.3 heads to boost compression.
You'll also need an LS car intake manifold to fit the motor in the Impala bc truck intake is too high.
In addition, you'll need all the accessories off of the van and headers.
SpeedEngineering makes a good inexpensive set of headers from LS swaps.
I'd also consider replacing the pistons with flat tops since it is the lower compression LQ4.
Nab
Blue Wail is offline
post #3 of 17 (permalink) Old 05-22-2019, 03:17 PM Thread Starter
stock lt1 I thought was 260 hp stock 6.0 is 300 stock will I not notice the increase in power for some reason?
Sent from my SAMSUNG-SM-G890A using Tapatalk
cor1987 is offline
post #4 of 17 (permalink) Old 05-22-2019, 09:11 PM
KW Baraka's Avatar
The total cost/effort of a LSx swap for 40hp gain is.....depressing.
As Nab stated, get new pistons/cam/heads for power.
A nice combo with compression around 10.5:1 to 11:1 can easily get you about 425 HP.....to the wheels.
That's about twice the power you have right now.
Jus' sayin'.
KW
KW Baraka is offline
post #5 of 17 (permalink) Old 05-23-2019, 06:37 AM
Blue Wail's Avatar
As a comparison, a stock LT1 will make over well over 300 HP with headers and fresh valve springs.
Nab
post #6 of 17 (permalink) Old 05-23-2019, 04:07 PM
capriceutah's Avatar
Use the F body pan
You could use sloppy stage II cam
https://sites.google.com/site/sloppy...sloppy-stage-2
PAC 1218's
https://www.ebay.com/itm/PAC-LS-Valv...ty!84121!US!-1
You may want to look for some 243 or 799 heads off of a new 5.3 truck motor.
This guy is talking about making a crossmember and I know clearimage was making one. Most likely you will need to ghetto fab
https://www.impalassforum.com/vBulle...-supports.html
95 Caprice Wagon 100 K daily driver.
72 Chevy C10 1/2 ton longbed parts hauler-Sold
72 Buick Skylark 350 56K-Rollin Cragar SS's now Buick 455 in the engine bay,
capriceutah is offline
post #7 of 17 (permalink) Old 05-23-2019, 08:53 PM Thread Starter
okay not positive I am going to but if I do anything I would consider heads and a cam. I know what casting number heads to look for any info on what cam would work well and possibly hp numbers?
cor1987 is offline
post #8 of 17 (permalink) Old 05-24-2019, 06:28 PM
Full disclosure
I have everything for my LS swap but mine is not done yet.
I just cant see taking a good running LT1 car apart.
The LT1 is a good motor but the resources for tuning and power parts are getting scarce.
If the engine decides to bow out gracefully, then I have a cammed 6.0 with 243 heads on deck
If you can get the heads cheap, like I mentioned do 243's or 799 casting. Otherwise don't worry about it. 317 flow well but the they are a lower compression head.
Here is a cam/springs only only LQ4 with stock 317
You can also decap the stock injectors and they come out to be about 75 lbs. Have them tested after decapping. Here is an instructional video
If I was going to spend big money on anything it would be a converter for your new to you 4L80e. They are like a grand for a good one
post #9 of 17 (permalink) Old 05-24-2019, 10:17 PM Thread Starter
the reason I am doing the swap is the condition of my lt1 245000 on it runs poor think it's tuning issues. just can't see spending more money into it. I bought the express van for 700 so not to bad for money spent so far plus the tires on the van are like new and way better then the ones on my truck
cor1987 is offline
post #10 of 17 (permalink) Old 05-25-2019, 07:15 AM
gbhs72's Avatar
Maybe this will help you out. MuscleRods 91-96 Impala LS Conversion Kit
Mark: Snowman-33
gbhs72 is offline
Similar Threads
5.3 / turbo / 4L80 swap Master slacker Engine Performance 1 02-19-2016 08:38 AM
4l80 sticking in 2nd gear Klez Drivetrain 0 11-29-2011 11:57 AM
5.3 vortech 4L80 swap in 78 caprice 1978heavychevy Drivetrain 2 03-09-2009 07:06 PM
4L80 or T56? jerseykid96 Drivetrain 20 04-07-2008 11:09 PM
electronic 4L80 or nonelectronic 4L80....which one?? mexSSican Drivetrain 8 04-21-2002 07:28 PM
