Budget L05 build - Chevy Impala SS Forum
 1Likes
post #1 of 24 (permalink) Unread 07-12-2019, 12:47 AM Thread Starter
Budget L05 build
Putting together a vortec 355. Buddy had a free block and I’ve been wanting to ditch the 305
hit it with a hammer
IndyL03 is offline
post #2 of 24 (permalink) Unread 07-12-2019, 12:51 AM Thread Starter
Got this far before surgery earlier this year
IndyL03 is offline
post #3 of 24 (permalink) Unread 07-12-2019, 12:54 AM Thread Starter
Where I’m at post surgery
IndyL03 is offline
post #4 of 24 (permalink) Unread 07-12-2019, 06:03 AM
gbhs72's Avatar
Budget LO5 Build... Yeah I said that too. Stay away from Jegs & Summit catalogs. Keep up the good work.
Mark: Snowman-33
gbhs72 is online now
post #5 of 24 (permalink) Unread 07-12-2019, 08:53 AM
Make sure you get the LO5 computer, or at least the chip from an LO5 computer.
You can get a set of Vortec heads, and a manifold with TBI adapter for about a 40 HP increase over the stock rating. You can also put a cam in it, and get a chip burned for the cam/heads specs. You can also get a slightly larger TBI, but you will have to modify the adapter for the larger bores. Another option is to smooth the bores of the TBI you have to get more flow. You would also have to open up the distributor hole for the OEM distributor.
While you have it apart, try to get the fuel line from a 91-93 Fleetwood, with an LO3/5, or both lines from a 93 FW. Both will have a Schrader port to check fuel pressure.
Fred Kiehl is online now
post #6 of 24 (permalink) Unread 07-12-2019, 03:14 PM
gbhs72's Avatar
So here we go. https://www.impalassforum.com/vBulle...rformance.html With this you can tune your car with a lap top. Just like the big boys. http://www.dynamicefi.com/ Or you can just keep pulling the chip till you have the setup you want. Welcome to www.moates.net! : Moates.Net As far as the intake this is possible too. TBI Intake Manifold You may want to do the Caddy CAI mod too. Fred^^^^^^ has one of the Caddy hats for sale. Now to keep your heart in this, check these out. https://www.impalassforum.com/vBulle...otor-pics.html You have been warned. Best O luck.
Mark: Snowman-33
post #7 of 24 (permalink) Unread 07-12-2019, 03:34 PM
Mark: Snowman-33
The Caddy hat needs to be modified a little to work right. I have since begun using the Spectrum carb hats on my engines (post 4 of the last link). The TBI computers can not be tuned with a laptop, The tuning is in the chip, and they must be "burned" for the setup you have. The guy at dynamicefi can burn them for your "formula".
A couple of areas that need to be addressed. DO NOT lift the engine with a carb plate if you put the Vortec heads on it. You must also use the Felpro 98000T gasket set, or it will probably leak initially, or will leak in the future. Use the original LO3/5 water pump, and FEAD.
post #8 of 24 (permalink) Unread 07-12-2019, 05:13 PM
gbhs72's Avatar
Fred, Normally I look to your advice on these cars. This one time you're not seeing all that is in the Dynamic link. They add an additional board that allows you to connect to a computer. Just a little from their site.
"The EBL system sends ECM data to a laptop or PC running the What's Up Display program. It is simply the best and fastest data logger available for any GM ECM. The data stream contains all available engine and vehicle parameters."
It uses TunerPro. http://www.dynamicefi.com/Tune_Intro.php
Mark: Snowman-33
post #9 of 24 (permalink) Unread 07-13-2019, 07:06 AM
Gbhs72, the program you have referenced is for a flashable OBD1 computer (94-95 and some others). The 91-93 systems are not flashable. They require a base tune that is burned into the removable chip. The parameters may be able to be read, but the reference maps can not be changed on the 91-93 chip computers without changing the chip.
post #10 of 24 (permalink) Unread 07-13-2019, 07:45 AM
Sinister's Avatar
Do you even read the links people provide?
http://www.dynamicefi.com/EBL_SFI6_Flash.php
Says right there...
"The EBL SFI-6 Flash does away with the burning and swapping of chips. On-board flash is programmed with the What's Up Display. No more swapping chips, no more ECM on the floor of the vehicle. Put the ECM back into place under the dash (or seat, or kick panel or wherever it is intended to be). Then flash and data log a new calibration right from the same cable via the What's Up Display program."
gbhs72 likes this.
1995 Caprice Wagon
Sinister is online now
