RAISS Throttle body to MAF coupler - Chevy Impala SS Forum
 2Likes
  • 1 Post By angelo
  • 1 Post By gbhs72
post #1 of 9 (permalink) Old 08-14-2019, 06:05 PM Thread Starter
Can anyone verify this is the correct part # fernco boot, part # 1059-33 for the Throttle body to MAF flexible coupler?
thanks.
Willie
95 SS DCM
Tulsa, OK
wknox is offline
post #2 of 9 (permalink) Old 08-15-2019, 10:29 AM
angelo's Avatar
it says 3 inch by 3 inch, not sure that will fit on the throttle body, cuz stock is elliptical shape and about 4 inches i think.
They may sell that at Home depot, so buy it try it and return it if no fit ?
HD sewer pipe with stock maf
http://carphotos.cardomain.com/ride_..._large.jpg?v=0
SStudio boot with i think 3" by 4"
http://carphotos.cardomain.com/ride_...iginal.jpg?v=0
-ALF out...
wknox likes this.
angelo is offline
post #3 of 9 (permalink) Old 08-15-2019, 11:01 AM Thread Starter
Thanks Alf.....
that part# was from older post on forum. I like that sstudio boot, but trying to find manufacture.
thanks
Willie
95 SS DCM
Tulsa, OK
wknox is offline
post #4 of 9 (permalink) Old 08-15-2019, 11:21 AM
angelo's Avatar
Hi, Good luck finding that, they went out of business and new place zzstudio i think was called was selling and they went belly up too... you can search forum for posts on it.
i think searching silicone coupler will get you plenty of threads with option on what will connect the TB to the MAF.
-ALF out...
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #5 of 9 (permalink) Old 08-15-2019, 08:20 PM
3.25 x 4 inch is the proper size. A reproduction part that I use for my Suncoast air-box https://www.hawksmotorsports.com/94-...ion-slp-style/ ... The MAF will require "sleeved" with a short piece of 3.25" hose as this piece's MAF diameter is 3.5"
post #6 of 9 (permalink) Old 08-16-2019, 06:28 AM
gbhs72's Avatar
I don't know exactly what you need but, I did have this in one of my saved sites. Intercooler Pipe Fabrication Maybe something there for you.
Mark: Snowman-33
wknox likes this.
gbhs72 is offline
post #7 of 9 (permalink) Old 08-16-2019, 06:34 AM
juniorwatson's Avatar
thanks.
Do you still need this information? I have all of my receipts for my purchases throughout the years at home in a binder. I glanced through it a month or two ago, and I specifically recall seeing the receipt for the silicone boot.
I can get it for you tonight when I get home, just LMK if you need it.
juniorwatson is offline
post #8 of 9 (permalink) Old 08-20-2019, 05:54 PM
killian96ss's Avatar
Do you still need this part? I have some leftover parts from my 96SS and I remember having the stuff for that intake setup, specifically the short MAF to TB adapter which I believe is from an LT1/4 corvette. I can get a pic if your interested.
Steve
Black 1996 SS, lot's of mods
killian96ss is offline
post #9 of 9 (permalink) Old 08-23-2019, 10:11 PM
This is the coupler I have. It's also for sale with the MAF extension harness included.
ID:	183828Click image for larger version
ID:	183834Click image for larger version
Steve
