Alarm reprogram help - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 11-09-2010, 02:50 PM Thread Starter
easy79's Avatar
How can you program a key fob for the GM factory alarm.
I have 93 Caprice
easy79 is offline
post #2 of 4 (permalink) Old 11-11-2010, 03:31 PM Thread Starter
easy79's Avatar
Bump, no one knows how to reprogram a factory alarm? Just want to know if I can by a key fob and program one to the factory unit?
easy79 is offline
post #3 of 4 (permalink) Old 11-20-2010, 11:19 PM
bad4health's Avatar
theres a thread on here about it. i think you have to short 2 wires together from a box behind the rear seat an hit the lock or unlock button a few times.
95 WX3 BBB, 6.2L Supercharged Gen 5 Lt, 4 SA-12s, Cadence C6, Beyma 6.5s, 300.4, 1/0 Wire, Double Din w/Navi DAILY DRIVER
mods please change bad4healths name to the GREATGORDofISSF. may the pulp be with you :P
bad4health is offline
post #4 of 4 (permalink) Old 11-20-2010, 11:26 PM
94MI9C1's Avatar
If it is anything like a 94-96 in the trunk in the harness that runs along the left rear fender there is going to be a plug that isn't plugged to anything, stick a piece of wire in there to short or jumper the pins together and the locks and trunk solenoid will cycle once to tell you it is in program mode, hit one button on the remote only once, if it works the locks will cycle again saying it is programmed, remove jumper wire and test it out.
Looked in a 93 FSM and you may have to turn the key on.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
