Car can start in any gear P,R,N,D,3,2,1 after recent alarm install. - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 02-12-2011, 10:05 AM Thread Starter
I just had my python 1601 installed and now my car can be started in any gear. I also do not have to push the brake to change gears(from park to drive) I can just pull the lever down. I am thinking they might have messed something up when they soldered something in place of an ignition bypass module, although I do not know for sure. Had anyone had any problems like this or have any ideas as to why this is happening?
1994 Caprice 5.7 with 55,xxx miles, still going.
jd87sep is offline
post #2 of 5 (permalink) Old 02-12-2011, 05:30 PM
elbringit's Avatar
It has something to do with the BTSI (brake-transmission-shift-interlock) thats all I know. Hope it helps you go from there
1995 B4U-running motor delete
elbringit is offline
post #3 of 5 (permalink) Old 02-13-2011, 06:59 AM
it has to do with (transmission neutral safety switch)
when you don't know what to do,do what you know
ahoora is offline
post #4 of 5 (permalink) Old 02-13-2011, 09:02 AM
94MI9C1's Avatar
This is a correct statement but it is going to be a two sided thing, if it starts in gear as well.
Do your reverse lights light work?
Did it have keyless entry from the factory?
If it starts in gear, the neutral safety switch had a couple of wires installed on it, the org/blk wire feeds a ground to the PCM when it is in Park or Neutral, telling the pcm to start. The neutral safety switch is also the first point in power distribution to the BTSI solenoid..
So ahoora was right it sounds to me like it is a neutral safety issue, if a shop did this install take it back and tell them to fix it
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #5 of 5 (permalink) Old 03-18-2011, 02:33 PM Thread Starter
Thanks for the help, finally have time to take it back to them(the shop)
jd87sep is offline
