Remote start, won't stay running - Chevy Impala SS Forum
post #1 of 20 (permalink) Old 07-23-2007, 11:58 AM
SS64SS
I'm hooking up an alarm/remote start. It's a Alpha Guard AG-95s Alarm/start. I have it hooked up, and the remote start works, but it starts then stops, and does this 4 times in a row, than quits.
There is one wire I haven't hooked up, because I'm not sure where to put it. It's described to hook this wire up to the "oil indicator/high tension wire" It says it should blink on the dash when the car is started...but not sure which one I should hook it up too...I doubt I hook it up to my oil dummy light.....ANY HELP?? Thanks
post #2 of 20 (permalink) Old 07-24-2007, 02:20 PM
okc96bbb
if you used tach wire it must be programmed/learned. [img]graemlins/5.gif[/img] i've been doing this 25 years. barrel into install then read manual. [img]graemlins/.gif[/img] it becomes very clear then.
post #3 of 20 (permalink) Old 07-24-2007, 03:03 PM
SS64SS
I did not hook up a tach wire at all....??
Is it a must for remote starts?
Would this oil indicator/high tension wire be hooked up to my tach wirethen? The manual says this wire must be hooked up for the remote start to work.
The wire comes from the side on the brain box, its not apart of the wiring harnesses that clip on....if that clears up which wire it is??
THanks for the help.
post #4 of 20 (permalink) Old 07-24-2007, 03:44 PM
okc96bbb
post instruction manual & i will try to figure it out. [img]graemlins/3.gif[/img]
post #5 of 20 (permalink) Old 07-24-2007, 07:38 PM
SS64SS
ALPHAGUARDS AG-95S
Installation Guide (Diagram on Page 14)
There are 7 sockets on the side of the module.
STARTER
The 6-pins harass on the right of the module connects to the starter (igniter). Particular
wire identification is as below:
Black -> Ground
Red -> Ignition power
Yellow -> “Start” position
Brown -> “ON” position
There are two brown wires. The number of brown wires used
depends on the number of wires already connected to the “ON”
position. If there is only one then one brown wire is used. In that
case, leave the other brown wire alone.
Blue -> “ACC” position (ACC = air condition)
Cut off -> Engine cut-off relay
OUTPUT DEVICES & CENTRAL LOCK
The 10-pins harass next to the starter harass connects to output devices and central lock
system. Particular wire identification is as follow:
Pink -> Siren
Blue Black -> Trunk release, (-) 100mA
Brown x 2 -> Direction lamp (L & R)
The following 6-pins connect to the central lock module (sold separately). There are 4
different connection types (see Page 16). Particular wire identification is as below:
Orange -> Central lock module
White -> Unlock^
Yellow -> Negative
Orange Black -> Central lock module
White Black -> Lock^
Yellow Black -> Connect to Yellow for close circuit
The yellow black is connected to the yellow, and then yellow
connected to the common line. This way the circuit is "closed";
otherwise the connection won't work.
^ White and White Black are exchangeable if needed.
Note: Common line = negative polarity, NOT ground
Tips: The 1st diagram and 5th diagram suits most cases (based on the fact that most
vehicles use negative polarity for power locking).
HARDWARE SETTING
One jumper next to the central lock harass configure automatic arming mode (see Page 9).
INPUT DEVICES
The 4-pins harass next to the jumper connects to input devices. Particular wire
Blue -> Door pin switch (-)
Depending on the polarity used for power locking, use only (-) or
(+) to connect to the door pin switch***.
Blue White -> Door pin switch (+)
*** Please refer to Blue
Orange -> Handbrake light
This wire must be connected to activate the remote start
function. The system monitors if the handbrake is applied. If the
handbrake is not applied the system will reject all remote start
requests.
White -> ACC on
SHOCK SENSOR
The 3-pins harass next to the input devices harass connects to the shock sensor.
*ULTRASONIC SENSOR*
The 3-pins harass can be used for connecting to the ultrasonic sensor (sold separately).
LED
The 2-pins harass next to the shock sensor harass connects to LED light.
ANTENNA
The 1-pin harass next to the LED harass connects to antenna.
FROM MAIN MODULE
One yellow wire from the main module connects to oil light / tension coil.
Yellow -> Oil indicator light/High tension wire
function. There are two ways to connect this wire. It can be
connected to (1) the oil indicator light* or (2) the high tension
wire** (see Page 14).
* The oil indicator light should be on the dashboard. It usually
blinks when starting up the vehicle.
** The high tension wire method is recommended only for older
vehicle.
post #6 of 20 (permalink) Old 07-24-2007, 07:43 PM
SS64SS
I hope this helps. I have most everything hooked up. The orange wire that says to go to the handbrake, I have hooked up to my brake light switch. Is this correct. In my instructions on the diagram it says to have it hook up to brake pedal. thanks for your help!
post #7 of 20 (permalink) Old 07-25-2007, 09:07 AM
okc96bbb
the orange hand brake wire needs to go on the park brake. there will only be one wire at the top of park brake. it states it will ignore all remote start commands if not connected.
post #8 of 20 (permalink) Old 07-25-2007, 10:18 AM
SS64SS
Ok I will try switching that wire over to the parking brake....I just assumed that was for manual cars that the parking brake would need to be applied.
What about this wire though????? I do not have it hooked up anywhere???
FROM MAIN MODULE
vehicle.
post #9 of 20 (permalink) Old 07-25-2007, 11:29 AM
SS64SS
I've been searching on forums..and it SEEMS the "high tension wire" should be the tach wire. I will mess around with this during my lunch break with this wire, and the handbrake to see what happens.............
post #10 of 20 (permalink) Old 07-25-2007, 02:56 PM
SS64SS
Okay here's what I tried....the parking brake made no difference. I tried it with it applied, and un-applied.
I hooked up the yellow wire to the tach. And when I did that when I hit the button to start it....it cranked the car over...but didn't start it. It only did this once, then my lcd remote showed that the engine was running....when it wasn't.
Then I tried again with it un-hooked, and it would start it like it did before.....but it turns off arter 2 seconds of running......
