Python 871XP - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 08-13-2005, 02:52 PM
Erik
I just bought this alarm and I'm planning to install it myself in my '96 Impala. It comes with an installation manual and I went to the ICDynamics website and printed off the wiring list for a '96 Impala. Are there any other good sources of information? Better installation instructions or more detailed wiring information? Any good advice? Thanks.
post #2 of 6 (permalink) Old 08-14-2005, 02:19 AM
Erik
TTT I also went to the12volt.com and printed off their wiring info. I'll be away from the Forum today and most of tomorrow, but any additional advice would be appreciated. Thanks.
post #3 of 6 (permalink) Old 08-15-2005, 02:49 PM
Erik
Anybody?
post #4 of 6 (permalink) Old 08-16-2005, 05:41 PM
Erik
Last try.
post #5 of 6 (permalink) Old 08-16-2005, 06:32 PM
chevmdnss
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / IMPALA / 1996 / Remote Start
[PRINT THIS PAGE]
12volts red + ignition harness
Starter yellow + ignition harness
Second Starter
Ignition pink + ignition harness
Second Ignition
Third Ignition
Accessory orange + ignition harness
Second Accessory
Keysense
Power Lock lt. blue + drivers kick panel
Power Unlock white + drivers kick panel
Lock Motor gray dirvers door harness
Unlock Motor tan drivers door harness
Parking Lights+ brown or purple + headlight switch
Notes: Also found low in the drivers kick panel.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger white - underdash light
Dome Supervision use door trigger
Trunk/Hatch Pin dk. green - low in drivers kick panel
Notes: Only available on some models.
Hood Pin
Trunk/Hatch Release black/white + at switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer red/black AC 4 pin plug below intake
Notes: Remove the air cleaner assembly to access the connector. The connector is located a few inches from the center of the motor towards the passenger side. The motor will not start with the air cleaner assembly removed.
Wait to start
Brake Wire white + at brake pedal switch
Parking Brake
Horn Trigger black - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
VATS
Part #: 652T resistor pack
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: See DirectFax document 1049 for interface information.
warning
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
post #6 of 6 (permalink) Old 08-16-2005, 08:41 PM
Erik
Thanks!
