What wire is the door lock actuator drvr side? - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 08-12-2005, 05:28 PM
bigburb
trying to install an alarm system, i opened up the 'harness' that comes out of the driver door and there is a lot of wires in there. i just need to know what wires control the door lock actuator in just the drivers door.
post #2 of 5 (permalink) Old 08-12-2005, 05:44 PM
jee
I went to check on my 95
small white and small light blue wire. can remeber which does which, send them 12V each to test out.
small orange provide juice.
in the driver door wiring, you may find that the orange wire is in the small pack, and the light blue and white in the big pack of wire.
make sure the wire is white not white-tan else its the door open switch
post #3 of 5 (permalink) Old 08-12-2005, 06:26 PM
bigburb
yeah i've found those wires... what i need is wires that control the unlock for just the driver door power door lock motor (wiring up an AM1 and it needs to know when to disarm the system)
post #4 of 5 (permalink) Old 08-12-2005, 06:45 PM
bigburb
trial and error, i found it
post #5 of 5 (permalink) Old 08-12-2005, 07:57 PM
LavaSurfer
If you are trying to get the "2 stage" unlock working on a factory keyless, the easiest way to get that wire is just to shot one through the grommet into the door and yank the panel off and go straight to the actuator.
