engine issues - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 04-08-2019, 02:34 PM Thread Starter
StarReign's Avatar
engine issues
Hey all,
I recently did a tune up on my 93 caprice wagon and everything was great for awhile. Then at interstate speeds (or when towing something), I noticed that I would lose power, the check engine light would come and then it would start to overheat. Any suggestions?
StarReign is offline
post #2 of 6 (permalink) Old 04-08-2019, 03:33 PM
See what codes are stored causing the check engine light.
Most chain autoparts stores will do this for free (Auto Zone, Advance Auto, Orilies, etc).
What was involved in your tune up?
Fix Until Broke is online now
post #3 of 6 (permalink) Old 04-08-2019, 05:20 PM
babywag's Avatar
for a '93 OBDI all ya need is a paperclip to check codes
babywag is offline
post #4 of 6 (permalink) Old 04-09-2019, 08:20 AM
There are two things I would check first. I would check the O2 sensor/computer ground at the thermostat housing. If that does not help, I would also check the O2 sensor itself. The O2 sensor is easy to replace. It is on the front of the driver's side exhaust manifold, and can be removed with a box end wrench if you disconnect the wire, and thread it through the wrench.
I have had the alternator bearings self destruct and cause a load on the engine. The alternator self destruction can also stop the engine.
post #5 of 6 (permalink) Old 04-09-2019, 09:09 AM
Originally Posted by StarReign View Post
Hey all,
How recent is recent? And how long is 'awhile' that it ran great?
Like Fix Until -, I am interested in what this tune-up included. Did you otherwise open up the cooling for an unrelated reason? Is this overheating something you watch on a gauge, or do you just have an idiot light? Are you losing AF?
96 Black is online now
post #6 of 6 (permalink) Old 04-09-2019, 07:01 PM
Hey all,
I would lean towards bad O2 sensors I had same type of symptoms.
Impalapro is offline
Similar Threads
issues isssues and more issues IGOTTA96 Engine Problems/Maintenance 4 07-24-2013 10:36 PM
lots of issues after engine swap chadgoertz PCM Programming/Engine Management 6 10-10-2009 04:20 PM
Corvette Engine Dress install - issues 4DoorSS Engine Problems/Maintenance 5 07-29-2009 11:11 PM
Engine Block Knock Sensor Issues ChriSS K Engine Problems/Maintenance 10 12-09-2008 10:45 AM
Engine Swap Electrical Issues misterboston Electrical 7 09-23-2008 12:16 AM
