Header fit - Chevy Impala SS Forum
LinkBack Thread Tools
Old 03-02-2019, 11:05 AM Thread Starter
Big Jack's Avatar
Header fit
Hi guys, I'm contemplating getting long tube headers. Where I live, the only law is that 1991 and newer cars must have cats. I've deleted the smog pump & piping, so I assume that this allows for more header options that will fit. What body & year car headers will fit the LT1 B? At some point in the future I'd like to go turbo and/or LS motor, so not looking for something that'll last forever.
Remember, when not sure what to do, hit the throttle.
It may not end well, but at least it'll end the suspense.
Big Jack is offline
Old 03-03-2019, 02:36 AM
tayto is online now
Old 03-04-2019, 11:08 AM
+1 to the Tri-Y , I wish I had done these instead of the BBK's....
Blakjack is offline
Old 05-04-2019, 08:42 AM Thread Starter
Big Jack's Avatar
If/when I have the $, I'll definitely get the CIA tri Y's.
Anyone know if the flowtech 11100 / hooker 2451 will fit (assuming cats are reworked/moved)?
Big Jack is offline
Old 05-08-2019, 06:10 PM Thread Starter
Big Jack's Avatar
Originally Posted by big jack View Post
if/when i have the $, i'll definitely get the cia tri y's.
bump bump
Big Jack is offline
Old 05-08-2019, 07:47 PM
Why do I think you mean the Flowtech AfterBurners?
Coated http://www.summitracing.com/parts/BIG-49100-1FLT/
These are widely regarded by the ISSF for over a decade, for much less than the CIA's options.
Here, dig this for more info.
https://www.impalassforum.com/vBulle...ners-info.html
They are NOT Lying to You
You are Not Lying to Yourself
Alone
1g1bl82p7rr127841 RIP,IP
Marky Dissod is offline
Old 05-09-2019, 04:10 PM
95wagon's Avatar
Big Jack, because you have a wagon with its boxed frame, it is very easy to modify a 68-72 GM "A" body cross member to fit.
Basically cut the ends off, weld on pieces of angle to sit on frame.
Doing this allows you enough length on both sides that you can mod the OE cats to sit beside the trans.
Mine was this way when it had an LT1.
Still use the cross member , just different cats with the LS
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
Old 05-15-2019, 07:11 AM Thread Starter
Big Jack's Avatar
Super Chevy dyno tested headers on stock exhaust system and found no increase in power (shorty headers, mind you).
I'd like to know what sort of power gain I could expect with long tube headers dumping directly through exhaust cutouts vs. manifolds & cutouts
www.superchevy.com/how-to/engines-drivetrain/sucp-0804-1996-chevy-caprice-performance-upgrades/
Big Jack is offline
Similar Threads
will any SBC shorty or midtube header fit our LT1? BeaSStin Exhaust 6 01-27-2009 11:17 PM
SLP header billet header caps. blingin96 Parts for sale/wanted 4 11-16-2008 09:44 PM
To header or Not to header..... on New Engine Start Up BigBlackBeaSSt Exhaust 8 03-23-2008 08:22 PM
96 SS Exhaust on a 93 Caprice Fit or No Fit CapriceLTZ Exhaust 5 01-05-2007 08:58 AM
Slip fit header pipes...how to seal? Bugman Exhaust 7 07-15-2006 04:28 PM
