Catalytic converter - Page 2 - Chevy Impala SS Forum
 3Likes
post #11 of 21 (permalink) Old 03-18-2019, 08:45 PM
babywag's Avatar
Bought one for a taurus we had, poorly made, didn't fit well.
Had to be modified or it would have torn into CV boot.
It was cheap and it showed.
babywag is online now
post #12 of 21 (permalink) Old 03-19-2019, 10:18 AM
killian96ss's Avatar
I just recently went through this here in CA. Back in 2006 when my 96 had about 50k miles I replaced the OEM cats with Catco cats mainly just to save the OEM's for a later date. In 2006 the CA laws were not as strict so I was able to order the non CA compliant Catco cats from Summit Racing.
Fast forward to now the Catco's were totally garbage with the catalysts inside falling apart and rattling inside the cases. I was surprised they were junk after only 50k miles of use, but as others have said they are poorly made. Btw, the Catco's look nothing like the OEM cats, so don't assume the smog techs won't notice the difference. Luckily I still had the OEM cats, so I threw them on with 4 new Denso 02's, new Autolite iridium plugs and Summit Racing plug wires. My 96 which now has 102k miles passed with readings that were similar to when it was new.
If I would have needed new cats the best option to save $ would be to buy some universal "weld in" CA approved Magnaflows. Just cut out the bad cats and weld in the new ones. Now you'll have new CA approved cats with the correct CARB stamp on them plus they'll be in the stock location using the factory tubing.
Steve
Black 1996 SS, lot's of mods
killian96ss is offline
post #13 of 21 (permalink) Old 03-21-2019, 12:54 PM
KW Baraka's Avatar
Originally Posted by killian96ss View Post
......Btw, the Catco's look nothing like the OEM cats, so don't assume the smog techs won't notice the difference.....
You used the same direct replacement cats I listed above in Post #6?
KW
1995 DCM SS, LS3, V-max 90mm TB, Lingenfelter GT1-1 cam, Headman 1 7/8 LT Headers, 2 1/2" cat-back, 3200 Circle-D TC, 3.73 gears -- 479HP/434TQ @ the wheels (Daily Driver)
KW Baraka is offline
post #14 of 21 (permalink) Old 03-21-2019, 04:45 PM
KW
I think so, here's a pic of the cats I took off recently. The OEM's were shorter, wider, dark titanuim color, didn't have heat shields and didn't have the 02's installed on the cat body.
Steve
KW Baraka likes this.
post #15 of 21 (permalink) Old 03-21-2019, 05:45 PM
IIRC, in CA a CAT must be within 3" of its stock location. Weld in is fine as long as it has a CARB# and for 96 (OBD2) the CAT needs that stamped on it and has to be the same diameter pipe as stock (2 1/4")
Back when I bought the MagnaFlo replacements I got the 2 1/2" ones (LT1 Vette cars) which was before the current code change.
BALLSS is online now
post #16 of 21 (permalink) Old 03-26-2019, 11:01 AM
Sexy96ss's Avatar
I also live in Cali & I just put in Walker cats on my 96 SS $300 each installed. I did it because cel was on but I don't have 2 smog it untill October.
Sexy96ss is offline
post #17 of 21 (permalink) Old 03-26-2019, 07:15 PM
Replacement Cats
I put Walker cats on my 1996 SS. I do not know if they meet CARB standards, but they bolted on just fine and dandy.
NiteOp is offline
post #18 of 21 (permalink) Old 04-03-2019, 10:02 AM
KW Baraka's Avatar
Originally Posted by sexy96ss View Post
i also live in cali & i just put in walker cats on my 96 ss $300 each installed......
Ouch!
KW
post #19 of 21 (permalink) Old 04-08-2019, 02:17 PM Thread Starter
4x4high's Avatar
Well I finally decided to bite the bullet this morning, I ordered up a set of Magnaflow CAT 448184 and 448185 and also 4 new AC Delco AFS75 02 sensors. I found a place that offered 20% off on the CATS and no sales tax and free shipping.
1996 DGGM Impala SS
4x4high is offline
post #20 of 21 (permalink) Old 04-11-2019, 08:55 PM Thread Starter
4x4high's Avatar
New Cat's arrived today as well as my new 02 sensors. I'm going to my buddy's shop Monday morning to install them. Going to swap out the driver side exhaust manifold also since I know the gasket has failed and I picked up a spare set of manifolds and resurfaced them already so it's just a quick swap. Going to also replace the knock sensor pigtail since I seen the insulation is completely gone from the wire due to heat from the last 23 years.
1996 DGGM Impala SS
4x4high is offline
Similar Threads
FS: 94-96 Impala SS Caprice Edelbrock Headers & Catalytic Converter twinzilla Parts for sale/wanted 5 10-31-2009 01:05 PM
Should I remove the Catalytic converter? crete Engine Performance 16 07-23-2009 08:50 PM
hmm what are some signes of a bad catalytic converter??? HustlePayper Exhaust 10 01-18-2009 11:58 PM
WTB:/ 1996 OBD2 Passenger Side Catalytic Converter SIMPSON Parts for sale/wanted 6 08-29-2008 10:19 PM
Catalytic Converter Bigmoe1315 Exhaust 1 04-05-2008 07:19 AM
