Wiring harness vs Tri-Y’s - Chevy Impala SS Forum
 1Likes
  • 1 Post By 96 Black
post #1 of 8 (permalink) Old 05-02-2019, 06:07 PM Thread Starter
twindaddy's Avatar
This question is for the Tri-Y crowd. How close is too close for the main wiring harness? I just installed the passenger side, after several test fits.
I feel comfortable with the clearance for the AC and heater hoses, but the harness just seems so close.
What do you guys think? Can you post some pics of yours for comparison? Thanks all!
BBB 96 Impala SS - 36,000 miles
100% stock
1st in class 2005 ISSCA Nats
Black 95 Fleetwood Brougham - 170k+ miles
2nd in class 2005 ISSCA Nats
14.944 @ 92.38mph 10/7/06 at Etown
94 Caprice Wagon - 121k+ miles
Beater for the youngsters
twindaddy is offline
post #2 of 8 (permalink) Old 05-02-2019, 07:01 PM
Glad you showed a pic. For that area I believe I just took my hand and bent the metal bracket back toward the firewall.
NADACOP likes this.
post #3 of 8 (permalink) Old 05-03-2019, 08:26 AM Thread Starter
twindaddy's Avatar
Of course! Not sure why I didn’t think of that. Thank you!! Plenty of room now.
100% stock
post #4 of 8 (permalink) Old 05-03-2019, 09:11 AM
Sure thing. Any time. It's amazing what can be accomplished with just a little careless action in the absence of any well thought out methodical planning.
Now in exchange can you point me to some posts with a little more info on that Cady of yours?
post #5 of 8 (permalink) Old 05-05-2019, 01:02 PM
Vendor
Glad you got the bracket/harness away from the header. You don't want to rub through the ceramic because it would expose the metal and rust could become an issue. if it did wear through, get some hi-temp clear coat and spray the area. VHT makes some in a satin and a gloss.
Clear Image Automotive (425)251-0329
Headers, exhaust & intake systems
[email protected]
http://www.clearimageautomotive.com/
Clear Image Auto (Dan) is offline
post #6 of 8 (permalink) Old 05-14-2019, 10:02 AM Thread Starter
twindaddy's Avatar
Well, not much out here lately. It’s been sitting for 8 years and I’m just now slowly bringing her back to life. Standard Impala bolt-ons, beefed up trans, 373/posi, suspension and brakes (converted rear drums to discs).
Used to run low 15’s. I did have a few 14.9x passes. I’ll have it back out this year.
100% stock
post #7 of 8 (permalink) Old 05-14-2019, 10:07 AM Thread Starter
twindaddy's Avatar
Hey, Dan! Thanks for the tips! 🙂
I just started it last night. I moved the bracket (and went over everything 15 times) before I fired it up. No rubbing or clearance issues whatsoever. Headers and cats bolted right up, fit like a glove.
100% stock
post #8 of 8 (permalink) Old 05-14-2019, 10:37 AM
After almost 10 years the most memorable things were the brake and A/C lines. Each took bending just a little, and I used some temperature tape on the brake line closest to the header. I noticed two years back the A/C line required re-adjusting at the A-arm as it had cut through the insulation but visually masked that the line was a RCH from also chafing. Edit: And perhaps redressing some wiring low on the driver side (oil level? O2?)
And appreciate the update on the Cady. It's always gratifying to hear others letting their projects die on the vine as mine has.
Last edited by 96 Black; 05-14-2019 at 02:00 PM. Reason: Jarring brain cells loose.
Similar Threads
Haven’t been here for awhile. SSmoothie Misc. 2 03-19-2019 08:22 PM
Hey what’s good forum fam Chevyboi96 New Member Introductions 0 08-26-2018 02:24 PM
Discussion: 4L60e vs 4L80e vs TH350 vs TH400 vs powerglide... big_tugg'SS Drivetrain 42 01-10-2009 07:08 PM
4.6L 32V Marauder can’t shake a stick at the 5.7 LT1 LT1_CRAZY Engine Performance 17 07-29-2002 10:41 PM
Why can’t I? LotSSofmusic Suspension 4 08-28-2001 10:38 PM
