cleaning clear coat off of chrome wheels - Chevy Impala SS Forum
 1Likes
post #1 of 25 (permalink) Old 11-30-2018, 07:20 PM Thread Starter
Red face cleaning clear coat off of chrome wheels
I got my 95 SS back from my paint man with a new paint job. It looks immaculate and I am very pleased with the work done on it for the price. There is one problem, I have chrome wheels and some of the clearcoat was over sprayed onto the wheels. What is the best way to get the clearcoat off so my wheels will shine again?
BH tuning, Transgo shift kit, Eaton posi W/ 3:73 gears, EDGE 9.5" 3000 stall , BMR rear lower control arms. BMR front and rear sway bars Hotchkis springs, CIA trans crossmember; 1.6 Pro magmuim RR; CIA budget headers w/ high flow cats; 2 1/2" cat back with X pipe; chrome dual cone CAI, 52mm throttle body, 30lb SVO injectors, Wilwood brake calipers, Power Stop drilled and slotted brake rotors, Bilstein shocks. Gary's 2 relay headlight harness. Gary's battery relocation harness
my95ss is offline
post #2 of 25 (permalink) Old 12-01-2018, 04:06 PM Thread Starter
Cool
4-0000 steel wool. Thants how!
my95ss is offline
post #3 of 25 (permalink) Old 12-04-2018, 07:06 AM
TGO
You should have taken it back to your paint man and told him to fix his sloppiness.
2001 Corvette ZO6
1995 Impala SS - H/C/I - BBB
TGO is offline
post #4 of 25 (permalink) Old 12-06-2018, 08:28 PM Thread Starter
He is a very good friend that gave me a $8000 paint job for the cost of materials==$950 It was our deal for me to clean off the extra polish mateial and the wheels. It took about 2 minutes for each wheel and about 1 hour on the polish in a few places. You can treat your friends anyway you want but for the deal I got I was happy to do it!
angelo likes this.
my95ss is offline
post #5 of 25 (permalink) Old 02-05-2019, 11:31 PM
Post some detailed pictures of brand new paint job....
1low96ss is offline
post #6 of 25 (permalink) Old 02-08-2019, 08:29 PM Thread Starter
I would love to but its back at my paint guy for some touch up
my95ss is offline
post #7 of 25 (permalink) Old 02-09-2019, 02:32 PM
Sophomore Member
0000 steel wool and cheap car wax is the best way to gently polish chrome wheels, and it takes brake dust right off! Way to go!
sherlock9c1 is offline
post #8 of 25 (permalink) Old 02-11-2019, 06:43 AM
defdaboss's Avatar
dont do this dry. soak in water and soap. works well on chrome and glass. do not attempt on paint.
defdaboss is offline
post #9 of 25 (permalink) Old 02-25-2019, 12:22 PM
wood95sslr's Avatar
I used acetone to remove the clear coat. Time consuming [cotton balls] but got the job done. Then used NevrDull to polish them.
i.e. man cave, clean rim and tire, good movie playing, tire on the deck; you should be done with removing the clear coat over the bare aluminum on one wheel before the movie is over.
Two things: ventilation and no smoking!
Worked for me.
Good Lord - my first post in months! New laptop due to blown hard drive in previous one.
dw
wood95sslr is offline
post #10 of 25 (permalink) Old 04-10-2019, 11:42 AM
cadejohnson58's Avatar
My stock 17" rims have im sure some clear coat still on them but it also has oxidation marks. Can I just scrub them down with 0000 grade steel wool with soap and water to get them back to the brushed aluminum look. Thank you
cadejohnson58 is offline
