275/40-20 on 20" x 10"s - Chevy Impala SS Forum
post #1 of 1 (permalink) Old 05-01-2019, 01:26 PM Thread Starter
Big Jack's Avatar
In case anyone is thinking about wagon rear wheel/tire fit:
Withe the rear springs removed, I raised the rear axle until the bump stops touched the frame.
Both rear tires would turn freely without any rubbing.
Wheels are 6mm offset.
There's about 3/8" clearance between sidewall & wheel opening flange, so I recommend hard bushings in upper trailing arms.
Fronts rub on outside edge over dips & inside with steering at lock (with about 1/2" of wheel spacers).
Looks pretty sick, might have to get some really short rear springs
Remember, when not sure what to do, hit the throttle.
It may not end well, but at least it'll end the suspense.
Big Jack is offline
Similar Threads
How will 20 x 8.5 and 20 x 10.5 ride on a 96Imapala? Is it safer to go 20 x 10? am686 Wheels & Tires 17 10-30-2009 12:44 PM
Am I better off running 275/40-18's instead of 285/40-18's on C5 wheels B'klyn9c1 Wheels & Tires 7 05-15-2008 11:52 PM
If you run 285/40/18 or 275/40/18 - What tire did you buy and how much did you pay? DREAMSS Wheels & Tires 11 02-21-2008 12:03 AM
""""""""" SOUTH EAST IMPALA SS RACING SERIES"""""""""" RamAirImpala Impala SS/B-Body Racing 83 10-17-2006 08:47 PM
Anyone with pics of 275/50/17's or 275/40/17's on wagons? or opinions? myasylum Wagons 7 12-31-2005 12:47 PM
