It's time...brake hoses - Chevy Impala SS Forum
post #1 of 25 (permalink) Old 06-28-2016, 02:03 PM Thread Starter
babywag's Avatar
Since I'm waiting for other parts to show, figured I'd do some of the other items on my list.
Brake hoses. Wagon has 141k on it, and these almost never get changed. On inspecting them, I verified they were the OE hoses.
Still have to do the rear hose, but until I get it off jackstands in front, too much of a PITA right now. Have to wait on that one for a while.
This is why I change them on every used car I buy
These aren't the worst I've seen, but they are still 22+ years old and showing their age. Good time to flush out all the old brake fluid as well.
The service records I got with the car show "brake fluid change" @ 107k, 9 years ago. So that's overdue as well.
Hoses and fluids are cheap, they should be checked and replaced, but rarely even get looked @
Since I haul my kids around in my vehicle I always feel better knowing the parts are new.
babywag is offline
post #2 of 25 (permalink) Old 06-28-2016, 03:34 PM
1slow96 is online now
post #3 of 25 (permalink) Old 06-28-2016, 03:46 PM
IMHO going with stainless lines vs rubber will, and did for me, greatly improve pedal feel and braking performance
there are a few offerings available including the 5th line
post #4 of 25 (permalink) Old 07-04-2016, 08:32 PM
ghetto wagon's Avatar
I had hoses that crappy 10 years ago. I still have the "5th" hose stock, The flare nut wont break, I have to heat it!
Even when you run braided hoses, replace them every few years, as you have no idea what condition the inner liner is in! I heard about braided hoses being pinched, but I never thought about it until a hose got kicked up andI had no brakes on that wheel! It was a 10 year old braided hose, I imagine the age of it was a contributing factor of its failure, maybe the hose formed a weak spot
Car still works MOD
ghetto wagon is offline
post #5 of 25 (permalink) Old 07-05-2016, 06:24 AM
Wicked96SS's Avatar
I got the complete kit from Russell and highly recommend it. Great quality.
If your rubber brake lines lasted 141K miles, these will easily do that and probably more. Of course an ounce of prevention...
I did the front, as they were a no-brainer. The rears on my car were fine, so I will save them for another time! The 5th one is a pain in the ass, but looked good to me.
1996 Impala SS (Original Owner, owned again)
2014 Camaro ZL1 (Also original owner )
Wicked96SS is offline
post #6 of 25 (permalink) Old 07-05-2016, 06:37 AM
Very good idea to replace the hoses and Change the Brake Fluid. Brake Fluid is probably one of the most overlooked maintenance items on a car. With the moisture absorption problems of brake fluid, it really should be changed on a regular basis. I just do a gravity Bleed at all 4 corners until clear and wipe down the MC reservoir with a lint free cloth when the fluid gets low enough. I don't think you would find many people who maintain their cars that also replace their Brake Fluid on a regular basis....if ever.
In addition to what your pics show of the outside of the hoses, they can also break down internally. I had issues where the rotors were warping after a few thousand miles and all new HW, Pads, rotors etc. Not until I swapped the Flex Hoses did the problem get resolved. I believe it was a problem internally with the hoses preventing the caliper from releasing and heating up the rotor.
I held off doing that Hose for years and finally got brave enough to give it a go. I did find removing what I could to get better eyes/hands/tools on it to be a big help. Along with soaking the fitting (numerous days) and cleaning it the best I could behind the Nut was very helpful. Once the nut breaks free, it's not too bad to remove but that is the most difficult and Scary part of this job. My fear was getting it to a point of no return where I would have to replace the metal line back there....not a job I would like to do with the body sitting on the frame.
I did this on a sedan, so not sure how different this may be on a wagon. But maybe this post may help, along with that entire thread when you get ready to do this.
https://www.impalassforum.com/vBullet...89-post28.html
It was a feeling of relief when the Nut broke free. I'm a strong believer of Cleaning the Metal Line just behind the Nut in an attempt to break that seal. Also tightening the fitting a little first if you have trouble getting it to break free. Good Luck.
post #7 of 25 (permalink) Old 04-30-2019, 07:18 AM
Sophomore Member
Is there any sort of brake hose replacement interval? Mileage or age? First time I replaced brake hoses was in 2001 on a 1987 model year car and it made a huge difference in stopping. I'm working on a 2007 for a friend and brake hoses are so cheap from Rock Auto and although they look good, I'm really leaning towards just replacing them while I'm in there. This is totally rust free west Georgia vehicle. Should I, or not?
sherlock9c1 is offline
post #8 of 25 (permalink) Old 04-30-2019, 08:19 AM
Blue Wail's Avatar
You always run the risk of breaking the bleeder screw off when
bleeding brakes so unless you are replacing the caliper
I wouldn't touch the brake line hoses.
Nab
Blue Wail is offline
post #9 of 25 (permalink) Old 04-30-2019, 08:34 AM Thread Starter
babywag's Avatar
I personally would replace them. They're old and it cannot hurt.
One of the most neglected items on vehicles.
Usually cheap too.
babywag is offline
post #10 of 25 (permalink) Old 04-30-2019, 08:37 AM
I haphazardly tried years ago for a set for FWB, and would sure like them on my current one. If their product offerings are anywhere as good as their communication philosophy, then this could be a promising lead:
"Here at Russell Performance, we value your business and are always here to offer guidance and support regarding all of our products. Our philosophy is that the telephone is the most effective way to communicate and trouble shoot any issues or concerns you may have. For that reason technical email support is not currently available."
I'll give them a call in a bit and report back. Has anyone had luck with a one-off set for the Cady? Sorry babywag for hyjack, but you got a good title for future search.
