Brake lines available - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 12-11-2018, 09:15 AM Thread Starter
Are the OEM metal pre-bent brake lines still available ?
1 of Mine rusted through... and most look rusty.
larryfs is offline
post #2 of 2 (permalink) Old 12-11-2018, 10:02 AM
juniorwatson's Avatar
I did a quick search thru a company called The Right Stuff. I was very happy when I used them when I did a frame-off restoration of my 1970 Oldsmobile 4-42. They provided stainless lines that were perfectly formed, and I didn't have a problem with one piece not fitting correctly.
I used them for brake and fuel lines. I didn't compare them for pricing, but wouldn't hesitate to use them again for any project.
juniorwatson is offline
