Budget rear disc conversion - Page 2 - Chevy Impala SS Forum
 2Likes
post #11 of 20 (permalink) Old 03-12-2019, 12:55 PM
Thanks Mark. Yah usually default to helping smaller scale operations whenever possible, but Jegs and Summit pretty much interchangeable. But I'll check both for avail./price when the choice is between them.
Keep the wheel straight as long as possible unless/until inevitably forced over to the nursing home route. I had to do that for an uncle I was close to. First - Visiting Nurse, then area Mennonites helped, then assisted care, then a full-care home. No matter how frequently the visits it was clear to catch him winding down in what turns out just a more cheerful and better decorated hospital room. At several $k/mo. it was a rather pricey path to the end of the line. Haha nothing quite like bringing the room down with our whining eh.
post #12 of 20 (permalink) Old 03-12-2019, 12:57 PM
1/4" is correct for rear. You only need the one valve which can go anywhere along the long run of brake line from the front to the back. Easiest to install where factory uses a coupler to join two lengths of line. Should be one,or two of those somewhere along it's length.
gbhs72 likes this.
post #13 of 20 (permalink) Old 03-12-2019, 01:09 PM
gbhs72's Avatar
Bob, thanks for the helpful words. Wife's aunt lives next door to us and my MIL is on the corner down from us. My wife is a retired nurse, daughter is a Paramedic, the lady next to wife's aunt is a nurse too (her friend). Me, I was a combat lifesaver in Desert Storm. We pretty well have it covered for now. With all these women to take care of I have a need for this forum to have guy talk.
I'm curious now if two valves would be needed with the ABS. Might be helpful for future questions on this mod.
Thanks too to all here for the information on our love affairs.
Mark: Snowman-33
gbhs72 is offline
post #14 of 20 (permalink) Old 03-12-2019, 01:15 PM
gbhs72's Avatar
Thanks for that info. Your answer about putting it inline should help others here. It's what I had planned on doing. I just haven't decided if I want it up front, might conduct some heat into brake fluid from exhaust heat, or further back.
Mark: Snowman-33
gbhs72 is offline
post #15 of 20 (permalink) Old 03-12-2019, 01:50 PM
Thanks for the backup confirmation on size. I thought the TC using a 4-channel system (including reluctors at each rear wheel) is to partially/temporarily brake a slipping wheel to favor the one with better traction. I'll be scoping out the ABS module on both my cars and count for an added hardline going to the back, and will report back.
post #16 of 20 (permalink) Old 03-12-2019, 03:31 PM
These valves are not intended to be used w/ABS.
post #17 of 20 (permalink) Old 03-12-2019, 06:22 PM
Originally Posted by 96 Black View Post
..........Enter the rear disc conversion (Navy's scoop-to-nuts design). Replace nosedives with flat front/rear squat, and the pedal had little travel and felt either on or off. In combination with both bolt mods the car braked like a built sport compact. A 4,500# one lol ......
Any links or more info on the rear disc conversion or bolt mods?
Fix Until Broke is offline
post #18 of 20 (permalink) Old 03-12-2019, 10:01 PM
Why not use the "search" function? None of this is new,and few are likely to repost info that has been posted many,many times.
post #19 of 20 (permalink) Old 03-13-2019, 01:59 PM
Blue Wail's Avatar
Replace the stock bolts/plugs in the brake proportioning valve with these to increase power to rear brakes.:
https://www.summitracing.com/parts/pof-112-10001
Nab
April's Sparkle Cat
383 LT1 12:1 flat top + 75 shot
11.66 @ 117 at SSHS17 Nov 11, 2017
2017 12.0 Index Champion
4140 lbs. w/ driver. front sway bar ON
Powered by 4L80E! (controlled by LT1 pcm)
Blue Wail is offline
post #20 of 20 (permalink) Old 03-13-2019, 04:41 PM
Nab
Thanks Blue Wail - I appreciate it. I found info on various brake upgrades, but nothing on this. Thanks again
Similar Threads
Rear drum->disc conversion. Questions. ALT-F13 Brakes 16 10-27-2008 01:17 PM
f.s=rear disc brakes conversion rag ss [clone war ss] Parts for sale/wanted 8 10-19-2008 04:20 PM
Rear Disc Conversion/Upgrades - Sedans Navy Lifer Vendor Area 4 10-01-2008 08:52 PM
SSBC rear disc conversion!! flatblack Brakes 4 01-09-2008 10:34 PM
96 RMW rear disc conversion begins peepaw79 Brakes 0 12-15-2007 01:44 PM
