ABS Pump Harness connector? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 04-20-2019, 10:15 AM Thread Starter
Not sure if this is touched on here already or not. But was curious if there would be issues doing this.
My ABS has long been dead but the ABS pump and metal lines are still in place along with the BIG Harness Plug attached the the pump. Doing some work on the car and found my custom intake fit much better if I just "unplug" the harness connector on top of the ABS pump housing. I covered the connector and harness plug to keep junk out. My question is, does this tie into the PCM at all and will there be any "electrical" or PCM issues caused by just unplugging this harness and letting it lay there for now??
post #2 of 4 (permalink) Old 04-20-2019, 11:25 AM
Deleted mine years ago... When peeling the wires back,don't recall any going to PCM. Did retain a bat+,and ign+ powered circuit on the driver's side inner fender to power any future accessories on that side of the engine compartment.
post #3 of 4 (permalink) Old 04-20-2019, 02:37 PM
babywag's Avatar
abs is an independent system while some of wiring is loomed up w/ rest, nothing goes to the pcm.
babywag is offline
post #4 of 4 (permalink) Old 04-20-2019, 08:45 PM Thread Starter
Thanks guys, kind of what I was thinking.
Update - harness removed and car ran/braked fine.
Similar Threads
WTB: C204 Engine Harness to Body Harness Connector westSSdad Parts for sale/wanted 4 01-12-2019 04:36 PM
Correct Connector For Vehicle Fuel Pump Harness? Wagon Collector Engine Problems/Maintenance 3 06-08-2015 12:37 PM
95-96 ABS harness connector question. NADACOP Brakes 0 05-11-2014 08:28 AM
What does this connector go to? (Near ABS controller, ABS doesn't work) TheFleshRocket Brakes 5 10-27-2011 09:50 PM
can i remove the abs harness and air pump harness pimpallya59 Engine Performance 0 09-30-2009 09:25 PM
