O'Rings and Brake fluid - Page 2 - Chevy Impala SS Forum
post #11 of 11 (permalink) Old 05-19-2019, 11:31 PM Thread Starter
I finally found a bone yard in Texas that had a combination proportioning valve from a 2003 S-10 with relative low mileage(117k). I replaced the Master Cylinder and the proportioning valve. I am back to normal. I believe that the master cylinder was leaking internally and the proportioning valve was leaking out of the rear port.
I took apart the proportioning valve and only a single o-ring. The other portions are rubber discs. I need to see if anyone has the replacement discs to rebuild the valve and just put on the shelf for later.
Thanks for the insight.
Michael
2012 Best of ISSCA; 2013 ISSCA Nats FTD Autocross and Road Racing
1995 BBB: - ERE383 #74 516 FWHP/526 FWTQ
1984 Monte Carlo SS 12.8 @ 104
2005 GTO M6 357.7 RWHP and 358.8 RWTQ PCMFORLESS
madamorr is offline
Similar Threads
E-brake leaking brake fluid? SS DD Brakes 25 10-05-2014 07:26 PM
Kore 3 Big Brake Abs Reluctor Tone Rings New BigMan95Impala Parts for sale/wanted 1 02-21-2010 09:12 PM
Brake Fluid - a forgotten element in brake performance? Navy Lifer Brakes 6 02-06-2010 09:48 PM
How much brake fluid should I buy to flush old fluid WindSSurfer Brakes 2 11-21-2007 07:15 AM
best brake pads ? blue brake fluid? outkastblue Brakes 11 10-18-2006 08:31 PM
