O'Rings and Brake fluid - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 05-05-2019, 10:43 PM Thread Starter
Greetings,
I am posting here for the infinite wisdom of the Impala community. I have a 2003 GMC Sonoma truck and the brake proportioning valve is leaking. Seems as if finding a new or rebuild unit is not going to happen.
So I may attempt to rebuild the unit and hopefully it is just a leaking o'ring. With that being said, what types of o'rings are compatible with brake fluid?
Viton, Nitrile, Neoprene, Ethylene Propylene Rubber(EPR), PTFE etc?
Thanks,
Michael
2012 Best of ISSCA; 2013 ISSCA Nats FTD Autocross and Road Racing
1995 BBB: - ERE383 #74 516 FWHP/526 FWTQ
1984 Monte Carlo SS 12.8 @ 104
2005 GTO M6 357.7 RWHP and 358.8 RWTQ PCMFORLESS
madamorr is offline
post #2 of 11 (permalink) Old 05-06-2019, 05:16 AM
gbhs72's Avatar
Michael, Hey this might help you out. eFunda: O-Ring Materials Compatibile with Chemical Brake Fluid
Mark: Snowman-33
I found another chart. https://www.marcorubber.com/o-ring-c...lity-chart.htm
gbhs72 is online now
post #3 of 11 (permalink) Old 05-06-2019, 06:54 AM
SAH62's Avatar
Originally Posted by madamorr View Post
Greetings,
Thanks,
Michael
EPDM (Ethylene-Propylene Diene Monomer) rubber is what you want. You're generally not going to find seals made from this material at your local auto parts store. I make rebuild kits for a number of applications (not yours, though) and have a pretty good collection of many sizes. If you can figure out what you need I may be able to help.
Scott Hollenbeck
Administrator, Mustang 428 Cobra Jet Registry
Owner, Muscle Car Research LLC
1995 DGGM Chevrolet Impala SS (original owner!)
(more non-GM stuff)
SAH62 is offline
post #4 of 11 (permalink) Old 05-06-2019, 07:41 AM
Did not continue to confirm stock, but it appears that part is available:
https://www.stockwiseauto.com/auto-p...C&Model=Sonoma
post #5 of 11 (permalink) Old 05-06-2019, 07:46 AM
gbhs72's Avatar
Bob, It's noted 0 stock.
Mark: Snowman-33
post #6 of 11 (permalink) Old 05-06-2019, 08:30 AM
Mark: Snowman-33
Lol - there's a lot of that going around. And thanks. What struck me search-worthy is checking (and you confirmed) that you can't get parts for even a 15-year old Chevy? The dealer can likely get one though. For say, $400?
For the OP, it may be out there, but just a thought to leave the valve intact while confirming the lines/fittings are not simply corroded or loose. Latter seems way more probable than the valve letting go.
post #7 of 11 (permalink) Old 05-06-2019, 10:16 AM
gbhs72's Avatar
I found that strange too. Says alot about the future.
I recently had a situation that backs this up. Check the simple things first. I told my wife several days ago that my truck was like her. Old, creaks & growns and drips a little. but it's faithful. I went out to start it and WTH? it cranked and stopped. No lights except the dash. I thought I heard a snap when it happened. Started checking fuses & relays. Turned out it was loose cable to the battery.
Mark: Snowman-33
post #8 of 11 (permalink) Old 05-06-2019, 10:19 AM
A little off the subject,but when I deleted the ABS off my C/K pickup. Added an aftermarket adjustable proportion valve on rear brake circuit. If/when rear brakes start to lock-up,then take a little percentage of brake force off. Continue until periodic adjustments like this until satisfied.
post #9 of 11 (permalink) Old 05-06-2019, 01:57 PM Thread Starter
Thanks guys you are helpful as usual. I will probably go to a yard and grab one then call on SAH62 to see if he has the proper o'rings.
FYI, the valve is leaking from the rearmost cap. When I press the brake, I see a pin protrude out the end and then I see a few drops of fluid. I do have a bad feeling that this may be a symptom of another problem.
I will get under the truck tonight and see if I have another leak. I have read that the pin should not show out of the valve unless there is a pressure loss somewhere else in the system.
Thanks again,
Michael
madamorr is offline
post #10 of 11 (permalink) Old 05-06-2019, 03:09 PM
Is there a an oncar diagnostic and instruction such as old prop valves had for "recenterng" subsequent to getting thrown over after pressure loss to one end?
Similar Threads
E-brake leaking brake fluid? SS DD Brakes 25 10-05-2014 07:26 PM
Kore 3 Big Brake Abs Reluctor Tone Rings New BigMan95Impala Parts for sale/wanted 1 02-21-2010 09:12 PM
Brake Fluid - a forgotten element in brake performance? Navy Lifer Brakes 6 02-06-2010 09:48 PM
How much brake fluid should I buy to flush old fluid WindSSurfer Brakes 2 11-21-2007 07:15 AM
best brake pads ? blue brake fluid? outkastblue Brakes 11 10-18-2006 08:31 PM
