Brake lines fitting size - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 05-08-2019, 07:52 AM Thread Starter
HUF
HUF's Avatar
What are the threads of the 3/16" rear lines FITTINGS at the hydraulic modulator?
My measurements show 10 x 1 mm and 12 x 1 mm. Am I correct ? Are they indeed metric? Hard to tell between 1.0 mm and 1.25 mm. Thanks!
There’s nothing as permanent as a temporary solution.
1995 Cadillac Fleetwood Brougham 126,XXX miles.
HUF is offline
post #2 of 3 (permalink) Old 05-08-2019, 08:25 AM
gbhs72's Avatar
HUF, Maybe this will help you out. Navy Lifer is always a good source. https://www.impalassforum.com/vBulle...-fittings.html
Mark: Snowman-33
gbhs72 is online now
post #3 of 3 (permalink) Old 09-06-2019, 09:33 PM Thread Starter
HUF
HUF's Avatar
Mark: Snowman-33
Thank you, Mark. The fitting indeed were 12 mm x 1 mm and 10 mm x 1 mm.
HUF is offline
Similar Threads
Brake lines - hard lines not flex lines Clear Image Auto (Dan) Vendor Area 28 06-09-2015 05:11 PM
Russell lines not fitting? DougDePew Brakes 5 01-08-2013 01:54 PM
Trans line pressure test port fitting size? RamAirRocket Drivetrain 7 10-22-2007 10:55 PM
ABS delete, fitting size??? mess21 Brakes 2 08-26-2007 05:20 AM
Fitting size for trans lines into and out of radiator windsurfer Drivetrain 1 08-12-2006 12:28 AM
