Another brake overhaul thread - Page 3 - Chevy Impala SS Forum
 2Likes
post #21 of 24 (permalink) Old 07-05-2014, 12:34 PM
95 impala ss front wheel bearing nut torque
Hi All
Does anyone know what the front wheel bearing hub nut torque should be?
Thanks
95impala ss is offline
post #22 of 24 (permalink) Old 07-05-2014, 02:36 PM
Originally Posted by 95impala ss View Post
Hi All
Thanks
12 ft lbs...BUT it is not a TQ and walk away deal.
TQ to 12 ft lbs while spinning the hub, back off till lose and by finger tighten nut so it lines up with hole for cotter pin
end play should be .001-.005 if you really want to check it that way after install. I have always just done it by feel after initial TQ, back off and then finger tight to the closest slot so the cotter pin goes through hole
BALLSS is online now
post #23 of 24 (permalink) Old 07-31-2015, 04:36 PM Thread Starter
SEO9C1's Avatar
Update to Rears...several years later
Nightmare replacing the rear pads and what went wrong:
Removing the piston from the brake caliper video
Inspecting the bore and piston of a disassembled unit and frozen slider pins video
Toms9C1 likes this.
SEO9C1 is offline
post #24 of 24 (permalink) Old 07-27-2016, 11:19 AM
Toms9C1's Avatar
Unhappy
I'm working on the driver side rear right now. Frozen slides I suspect.
Tom
ISSCA Member #2540
95 B4U: LT4 LE Cam 1.6 RR Eibachs 17" SS Whls K&N XPypes Mech fan delete+Gary's wiring harness RM Lthr seats Imp SS Rear Disc Eaton Posi Motive 3:73's Moser Axles Stainless brake lines NEW 4L60E/Dacco 2000
94 9C1: Eaton Posi 3:08's XPypes Stainless Brake lines
95 L99 DCM: SS Clone Vogtland springs Monroe SS shocks XPypes Front end overhaul w/Alum bushings
96 RMW Woody Black / Red guts
http://badass-of-ne.forumotion.com/forum.htm
Toms9C1 is offline
