Bill Harper (aka Navy Lifer) WX3 Z51 Rear Brakes - Page 2 - Chevy Impala SS Forum
post #11 of 34 (permalink) Old 11-09-2009, 10:58 AM Thread Starter
Location: CO: 75°F (late April) day 1 / Tornadoes day 2 / Snow day 3 / 65°F day 4
Thanks everyone.
It's Bill's WX3 rear brake upgrade kit and knowledge that made the difference. Bill was very supportive during the build and my countless emails and questions.
Originally Posted by WHITEBOY_ZACH View Post
I wish I could afford those brakes right now,.. but hey christmas is a comin. lol Ive been reading alot about this kit lately and I cant wait to grab one,..or two. lol
P.S. I wish my brake lines looked that nice, or my entire rear end for that matter.
Very nice set up, going on a very nice ride.
ZACH
Zach,
Thanks! The rear axle housing was the only original part that was reused during the build and it was media blasted and powdercoated. Everything else was new including new stainless steel hard brake lines.
Also, I patterned the rebuild off of a photo that HuSSker sent me of his rear axle build by RMCR.
Scott
westSSdad is offline
post #12 of 34 (permalink) Old 11-09-2009, 11:16 AM
How is the brake proportioning with this rear kit and stock fronts? How would it be with the.. HD12 (is that the correct reference) front brake kit?
94 9C1, 21%, 15x10's w/295's, Astro OH, Edge 2800, Built tranny, SSRI, 160 stat, Gary's Harness, ZQ8's, LT4KM, Stealth bolt, BH tune, 1.6RR, tru-trak and 3.73's, x-pype and aerochambers.
95 9C1, built tranny, Home Depot intake, otherwise stock with 404,000 Km.
Raxstone is offline
post #13 of 34 (permalink) Old 11-09-2009, 11:35 AM
Navy Lifer's Avatar
Stock & HD12 use the same front caliper piston size (area), just different caliper body casting width.
The smaller piston area of the C5/C6 rear caliper will provide slightly firmer pedal than the OE disc/disc system, but shifts bias forward, so it is definitely recommended to use the combination valve modification(s)--"stealth" bolt and/or metering plug--in conjunction with this F/R package.
The rear C5/C6 (standard or Z51) rotors are both larger in diameter than the OE rear rotor, so the clamping point is at a slightly larger diameter, for greater potential brake torque (longer lever).
The really good things about the C5/C6 rear brake setup are the much wider choice of pads, a wide range of rotors (all have to be modified for pattern and hub center size), and the much more substantial rotor mass and superior ventilation compared to the OE B-body disc setup.
Bill Harper
ISSCA #127
[email protected]
Navy Lifer is offline
post #14 of 34 (permalink) Old 11-09-2009, 11:33 PM
Wutz's HeavyChevy's Avatar
Your welcome.
Originally Posted by Navy Lifer View Post
John, thanks for the "props"....I can be quite a PITA as far as what people do or don't do with/to brakes. I'm glad to be in a position to help with information, advice or upgrade/mod solutions.
I hope your car is still staying as clean as the picture shows--it IS a challenge!
I'm helping out a member by doing a brake job for them for free.
Bill,
I briefly met you in person when you were our ISSCA Club President.
At our 2005 ISSCA Mountain Madness Nationals at the Pocono Speedway in Pennsylvania.
Thank you for the Compliment on my Impala SS.
After 45,000 miles of daily driving and three winters of rock salt being thrown at it.
I retired the SS from daily driving before the Winter of 98.
Mainly to save it from the 5 damaging months of Northeast Winter Rust.
Wutz
Capitol District of New York - ISSCA #1198 - UNYISSO & LISST.
Wutz's HeavyChevy is offline
post #15 of 34 (permalink) Old 11-14-2009, 07:44 PM
So, is there a Front Brake Upgrade that works with this?
OR, are the stock front's "Good Enough"???
BTW, they look GREAT (Both the Sedan and Wagon Kits!!!)
91 Caprice-For Sale
94 9C1-For Sale
95 SS Wagon-For Sale
04 Road King Classic-For Sale
05 CTS-V
95 Impala SS #94BBHP (Not Installed.....YET)
Gene is offline
post #16 of 34 (permalink) Old 11-14-2009, 08:29 PM
Freedog's Avatar
Send a message via Yahoo to Freedog
Two things that are on my wish list after I get a decent job 1) AVIC Z110BT 2) WRDC kit. Everybody cross your fingers, say a prayer, sacrifice a goat, whatever it takes for me to get another job please
Ruphrax sourced 1996 RMW
Caddy tail lights
2.5" catback w/flowmaster 40's, X-pipe, & 911 tips
Ram Air hood/intake
Smooth front bumper
Rear roll pan
Rear wiper delete
Custom SS grill
UMI LCA's
Electric fan conversion
Hotchkis rear sway bar
Eagle 20's
Bonnies
Intrax springs
Bilsteins
160 thermostat
Soon to come: Reflash, 1.6 rockers, gears, custom console, bags, custom sub enclosure, HUD, 19" LCD monitor in tailgate, Trans Am steering box,
http://www.cardomain.com/ride/3140885
Freedog is offline
post #17 of 34 (permalink) Old 11-14-2009, 08:32 PM
Navy Lifer's Avatar
Gene,
Good question--you have a number of options.
First, the understanding of "upgrade" has to be clarified. Here's my take.
The HD12 front kit is 100% bolt-on, provides greater rotor mass as it's prime feature. You can read more in the link. It will clear a 15" spare, if that is a concern.
Going with larger (diameter) front brakes than HD12 gets into knuckle modifications--it's no longer a simple bolt-on, but the changes aren't THAT difficult, just that some don't want to cut on a critical part like the steering knuckle (aka spindle).
There are several suppliers offering "big brake" packages for the front--typically, the Impala SS 17" wheel is the minimum needed to clear any of these kits--depending on rotor size selected:
KORE3 (primarily based on C5/C6 Corette OE parts)
TCE (custom kits using Wilwood calipers)
Baer (used to be C5 based, now have their own calipers)
SSBC (several different approaches--bolt-on calipers to stock rotors--not a true "upgrade"--and complete big-brake kits with their own caliper package)
Certainly the WRDC kit will still work with stock front brakes. You should at least plan to make the combination valve modifications (stealth bolt at least), if you do the disc conversion, to make the rear brakes do their share of the work.
Bill Harper
ISSCA #127
[email protected]
post #18 of 34 (permalink) Old 12-14-2009, 12:37 PM
Mr9two9's Avatar
Send a message via Yahoo to Mr9two9
So thats c5 z06 caliper, C6 z51 rotor(modded) After that, what else do I need?
"You're only as good as your last move..." - Unknown Motorman
1994 9c1 BBHP #144 (always being modded)
1995 Wagon (Retired - stripped to repair 9c1 theft damage)
1971 Buick Skylark (under construction)
Mr9two9 is offline
post #19 of 34 (permalink) Old 12-14-2009, 08:42 PM
Navy Lifer's Avatar
Quite a bit of stuff, actually....
2 C5 or C6 rear calipers—available in black or red--and now, raw aluminum, like B-body rear calipers
2 new backing plates modified for this upgrade OR exchange/modification of your backing plates.
2 new caliper mounting brackets, slide pins, boots, and fasteners
Caliper mounting bracket adapters, spacers, and fasteners
Park brake components assembled to backing plates (new)
Brake pads—OE (and ACDelco)--using Corvette brakes offers a wide choice of pads from PFC, Hawk, EBC, Satisfied, and a number of other brands—FMSI D732 spec, including semi-metallic, carbon-metallic, and ceramic friction materials.
All necessary hardware, gaskets, boots, fasteners, guide pin lubricant included.
Gear lube/additive and brake fluid not supplied with kit.
THICKER C-CLIPS FOR AXLE RETENTION & REDUCED AXLE END-PLAY are available.
Additional components are required for a full drum-to-disc conversions.
I've not updated this thread, since it's no longer accessible by me (unless Dilbert 9C1 gives me access to it) and I haven't re-posted it myself.
Note that rotors are not listed here--they come from KORE3, pre-machined to fit B-body (5x5) pattern and clearanced for the disc brake backing plate.
Clarifications (this is an upgrade for existing disc brake sedans):
Default pads are OE spec, with pad delete option.
Calipers are OE finish--black/gray is standard, Z06 red is optional, will be added cost in future.
Caliper brackets are modified for the application, and the adapter brackets are offered in 2 versions, for 12" or 13" rotors.
New caliper hoses are not required, but available--including braided stainless hoses.
This kit is for SEDANS, and is not compatible with Fleetwood 4-channel ABS axles.
Bill Harper
ISSCA #127
[email protected]
post #20 of 34 (permalink) Old 12-15-2009, 12:30 AM
I may be wrong but in the pictures it looks like has has 2 left side rotors.
Looks like the vanes on the rotor on the right axle are arcing forward at the 12 O'clock position. They should be arcing rearward like on the left side.
Phil M
ISSCA # 1322 Retired
2005 Ram Daytona(yeah its got a Hemi)
96 DGGM SS Sold
70 442 only looks Box stock
Azmotorhead is offline
