Checking/replacing cruise release switch - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 11-08-2015, 06:15 AM Thread Starter
Running through the stepwise diagnostics of my cruise control, it looks like it's saying to check the release switch that is tucked way up under the dash. Has anyone experience removing it? It looks like there's a retainer that comes off too? Does it help to remove the stop lamp switch that's right below it? It is fastened to the brake pedal bracket the same way as the cruise release switch
Alchemist is offline
post #2 of 9 (permalink) Old 11-08-2015, 06:53 AM
wytltng's Avatar
I think it should just pull out like brake light swtch
wytltng is offline
post #3 of 9 (permalink) Old 11-08-2015, 07:30 AM Thread Starter
I tried pulling on both switches. They seem locked in some way.
post #4 of 9 (permalink) Old 11-08-2015, 10:37 AM
Z09B4U's Avatar
Some ways are easy some are hard.
I find the easy way is to open the hood unplug the underhood cruise module and check the switch from the plug. This also checks the wire.
I do not like wasting time with the two screws and eight bolts to get to the switches then working under the dash.
If the switch is working why risk breaking it by removing it?
See your other thread: https://www.impalassforum.com/vBullet....php?t=1273681
Z09B4U
Z09B4U is offline
post #5 of 9 (permalink) Old 11-08-2015, 01:43 PM Thread Starter
I hear you. I was mistaken earlier. I double checked the flowchart and everything checked out, down to the PCM connector B terminal 8 showing ~7 volts (actually was a bit high, but I think my voltmeter 'zero' is off.
The manual says if all that checks out to do that manual test of starting car, putting cruise into run position, then waiting three seconds, push set and R/A together and hold, while depressing and holding brake pedal for 10 seconds. Release brake pedal and see if RPM jumps slightly. Mine did not, so it looks like my cruise control module is toast. Suppose I could swap out the one in my 96RMW with the one in the 95 Impala, but pretty sure it is the module. Likely something in the solid state/integrated circuit board?
post #6 of 9 (permalink) Old 11-08-2015, 04:52 PM
Z09B4U's Avatar
Correct me if I am wrong?
I thought OBD I cruise and OBD II cruise systems are very different.
Z09B4U
Z09B4U is offline
post #7 of 9 (permalink) Old 11-08-2015, 04:58 PM Thread Starter
You are right. The modules look very similar but the 94/95 are one part and the 96 is another. They are all discontinued and whatever is left some stupid ass wants $500 for. Screw that, I'm going to the yard later this week.
post #8 of 9 (permalink) Old 11-08-2015, 11:22 PM
Listening .
God Bless America!
1996 Impala SS DCM
1996 Impala SS BBB
1995 Buick Roadmaster Sedan
2014 Chevrolet VOLT
2016 Chevrolet Cruze
1986 Corvette Coupe
1988 Lincoln Mark VII LSC
1986 Ford F250 6.9 Diesel 4x4
Mikeceli is offline
post #9 of 9 (permalink) Old 11-09-2015, 05:35 AM Thread Starter
I'd bet there's some IC board in there that's identical between several GM vehicles. But not sure right now until I look.
