LED tail lights / bulbs - Chevy Impala SS Forum
 1Likes
  • 1 Post By govsux
post #1 of 7 (permalink) Old 11-16-2015, 02:44 PM Thread Starter
Didn't flash when I replaced the stock 1157 with LED replacements. Replaced right hand side relay flasher with NAPA part # EL-12 electronic Flasher problem solved. Posting for a search reference :]
Ree SS likes this.
govsux is offline
post #2 of 7 (permalink) Old 11-18-2015, 09:07 AM
You should replace your emergency flasher relay as well.
post #3 of 7 (permalink) Old 11-18-2015, 09:32 AM
streetcar2try's Avatar
So what is the reason why this relay works? Also, is the 4 way flasher the same style, blade wise?
94 ImpSS, Currently a 24x 383 LTx. Built by Me.
Machining by Competition Automotive & Machine
Harness by BP Automotive (Bill)
Tuning by James at Shortuning.com
Mike Harris Crossmember
much, much more....
streetcar2try is offline
post #4 of 7 (permalink) Old 11-18-2015, 09:58 AM
The relay is not really a relay, it is an electronic flip flop switch. It does not rely on a bi-metal strip to actuate. There may be a similar switch for the flashers. I do not know what the part number is. I believe the polarity may be different for the flasher unit.
post #5 of 7 (permalink) Old 11-18-2015, 03:09 PM Thread Starter
I my case I didn't replace the stock front turn signal lights so there is enough resistance that the stock flasher works when the flashers / turn signals are on.
govsux is offline
post #6 of 7 (permalink) Old 11-18-2015, 03:11 PM Thread Starter
4 way flasher is the same yes
The reason it's needed when changing to LED's is the old one requires some resistance in the circuit to make it work. LED's don't have enough resistance.
govsux is offline
post #7 of 7 (permalink) Old 02-28-2016, 06:15 AM
Send a message via AIM to Booth9C1SS
On related note, I recently got the new sylvania zevo led in 3157 for my truck and Like it. Have any of you tried the 1157 version?
Mine were the "Y" type that throw all of the light back toward the reflector.
Booth9C1SS is offline
