Blinker problems. PLEASE HELP! - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 12-13-2015, 06:52 PM Thread Starter
xx96CapriceLT1's Avatar
I have a 1993 Caprice and I'm really aggravated with it. When I turn my right blinker on with the lights off, both sides blink as if the emergency flashers are on, along with the speedo,climate control lights and plate light! When I turn the lights on and hit the right blinker, NOTHING blinks! Left blinkers works normal with lights on and off! I have no led bulbs in the car, and have replaced both blinker relays.
xx96CapriceLT1 is offline
post #2 of 4 (permalink) Old 12-13-2015, 07:22 PM
Z09B4U's Avatar
Roll up your sleeves
Could be a Grounding problem.
You will have to check several locations:
Harness to speedometer/gauges
Rear right brake socket
Front right turn signal socket
Z09B4U
Z09B4U is offline
post #3 of 4 (permalink) Old 12-15-2015, 04:00 PM
lights
You have a filliment that has dropped onto another one, thus making a circuit to other lamps. Replace the bulbs one by one until you find the culprit.
Charlie Costello
Charlie Costello is offline
post #4 of 4 (permalink) Old 01-11-2016, 11:25 PM
Signal swicht damaged
Your problem is at teering wheel column. The signal swicht has a mechanicalbad function and need to be replaced
JOSEFO is offline
