VATS and fuel pump enable circuit? - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 12-27-2015, 10:00 PM Thread Starter
Does a faulty passkey system (where the key resistance can no longer be read by the circuit), cause the fuel pump to operate??
This morning, I try to start my car and it cranks but doesn't fire. I also cannot hear the fuel pump whine, as is normally the case, when I turn the key. Looking at the factor service manual for my 96 RMW and a wiring diagram in the second book, it looks like the VATS system has something to do with enabling the PCM to allow operation of the fuel pump. My Pass Key light has been on (solid) for perhaps 4-5 months. Is it now not letting the FP work? As a check, the FP relay is fine, and the fuse is also fine. I WAS able to get the fuel pump to work using the underhood jumper to B+...
Any help appreciated.
Alchemist is offline
post #2 of 11 (permalink) Old 12-28-2015, 09:21 AM
Moderator
Goldmaster's Avatar
In a properly working VATs system, if the correct resistance from the key pellet is not seen upon a start up attempt, VATs will disable the cranking circuit/starter and fuel injectors (not fuel pump) for 3 minute intervals.
Goldmaster is offline
post #3 of 11 (permalink) Old 12-28-2015, 10:28 AM Thread Starter
So my engine cranks fine. And the fuel pump can be manually run (via the red jumper wire under the hood). But when starting now, I don't hear the fuel pump energizing. That damn Pass Key light has been on for months and no issues at all, but wondering if you can have problems with just the fuel circuit and not the cranking/starting circuit?
post #4 of 11 (permalink) Old 12-28-2015, 11:02 AM
If the pump works with the prime wire, it may just be a bad FP relay or the incoming signal to trigger the relay. Try to swap the relay and see what happens.
post #5 of 11 (permalink) Old 12-28-2015, 11:24 AM Thread Starter
I swapped out the FP relay with another known good one. No luck.
post #6 of 11 (permalink) Old 12-28-2015, 12:27 PM
Z09B4U's Avatar
Probe relay socket
The other quick test is to probe the relay socket coil contacts and confirm that the coil is getting voltage from the PCM. This can be hard to do as the PCM only turns the pump on for a short time at key on.
Last suggestion is one I have not done. Unplug the (orange?) wire between the ignition key lock and the VATS module. My 94 Manual says the car will not start the internet say it will but will light the VATS light.
The only sure way to rule out the VATS system is to look for it's 40-60HZ (AC) signal at the PCM. And the voltage out of the PCM to the relay
Z09B4U
Z09B4U is offline
post #7 of 11 (permalink) Old 12-28-2015, 01:02 PM
It sounds like you checked the schematic and it should resemble this circuit here for a 96.....
http://www.goldsswagon.com/diagrams/...ngine_3of3.pdf
....assuming you are getting the signal from the PCM to E9 and the ground is good, that should energize the coil and pull the relay contact over. You have bypassed this successfully using the override wire. As another test, try to jumper pins F9 and E11 and see if the pump runs.
If so, then I suspect you either don't have connectivity to E9 from the ECM or most likely you don't have a good connection to ground foil the coil in the relay at pin F11. Look where the coil in the relay is grounded. Good idea to remove that group of ground wires from the cylinder head, clean them and check them for a solid connection to the wire/ring terminal area and reattach to the head. Then see what happens. If you have no way to meter out these circuits, a quick swap of a known good ECM may be helpful.
post #8 of 11 (permalink) Old 12-28-2015, 02:02 PM Thread Starter
So are you all saying that the VATS would shut off BOTH the fuel and the starter, and not just the fuel?
post #9 of 11 (permalink) Old 12-28-2015, 02:50 PM
Moderator
Goldmaster's Avatar
If the car runs when you manually supply power to the FP, then it is definitely not VATS. As I mentioned, VATS disables the fuel injectors - not the pump.
Here is some good reading on the VATS system
https://www.impalassforum.com/vBullet...d.php?t=227294
post #10 of 11 (permalink) Old 12-29-2015, 09:30 AM Thread Starter
Ok. It's nothing to do with VATS. It's grounding. I think. The wipers also don't work and now they do. Along with the fuel pump. And car starts fine. I did run the FP jumper directly to battery and car started up just fine. I took the wire off and still runs. Restarted too. Does the ground for both the FP relay and wipers go to the front of left cylinder head??
