Fuel Injectors' fuse keeps blowing. - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 01-03-2016, 02:18 AM Thread Starter
Ali0Haider's Avatar
Question Fuel Injectors' fuse keeps blowing.
Hey there, so my problem is that one of the fuses of injectors keeps blowing right away. It happened before and I looked around for a short along the wiring for the injectors everything looks good. Next, I looked around the ECM (PCM? whatever) removed and inspected the plugs for a burn mark or something, nothing! to my surprise, when I plugged it back in and replaced the fuse it worked! but now it's back and tried the same thing but no luck. As soon as i put a new one and start the car it blows. Any Ideas?
Ali0Haider is offline
post #2 of 3 (permalink) Old 01-04-2016, 02:08 PM
Moderator
Goldmaster's Avatar
Electrical issues are not really my realm, but maybe its a shorted injector causing the issue? I'm just spitballing here, but maybe you could unplug all the injectors and install a new fuse and see what happens when you turn the key on. If it doesn't blow, then plug them in one by one and see if/when the fuse pops. Might narrow it down at least... I'm sure others will chime in with better suggestions though.
Goldmaster is offline
post #3 of 3 (permalink) Old 01-05-2016, 09:21 AM Thread Starter
Ali0Haider's Avatar
I tried to get a look at the injectors and their connectors, they seemed ok with good resistance. I gave up and called a shop who happens to have an electrician, told me that could be a short between the injectors' wires inside the loom, so he'll just check them out and maybe fix the whole harness if it's that bad. Thanks for the help though.
