Problem with cornering lights - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 01-13-2016, 09:56 PM Thread Starter
I wired up the cornering lights by following the instructions i found here on the forum. When i turned on the left turn signal, the cornering light blinked with it. When i turned on the right one it did nothing. Does anyone know what my problem might be? This is on a 95 Caprice.
95CAPRICE337 is offline
post #2 of 6 (permalink) Old 01-14-2016, 07:03 AM
Check your ground, and the wiring again. You may have grounded the cornering light through the small turn signal.
post #3 of 6 (permalink) Old 01-14-2016, 07:25 AM
Only adding to have someone else put eyes on your work and routing. You can be looking right at the cross-up and not see it. It's out there but you might be lucky for the right side and it's a bad bulb????
Curious what changed to necessitate re-wiring in the first place.
post #4 of 6 (permalink) Old 01-14-2016, 07:44 AM
91ss's Avatar
It's a real easy add. Did it to my 95 too. You should have just needed two taps for the wires going to the connector near the air cleaner. One for left other for right. Then just ground the other side of the bulbs to the body.
Probably tapped wrong wires. orange black sounds familiar.
91ss is offline
post #5 of 6 (permalink) Old 01-14-2016, 08:54 AM Thread Starter
Grounded to the body. Didnt touch the small turn signal.
1995 Caprice Classic White
New LT1 and rebuilt trans.
SS grille and spoiler,91-92 Tails
24" Black and Machined Irocs
Flowmaster Super 44s
Leather & Wood wheel
post #6 of 6 (permalink) Old 01-14-2016, 08:55 AM Thread Starter
The car didnt come with them. Brand new sockets and bulbs.
