Battery? - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 02-19-2016, 10:39 AM Thread Starter
Battery?
My 1996 Buick Roadmaster has 116,000 miles on it. When I drove it to work on Wed. I parked it same as always. But when I trued to start it 6 or 7 hours later it was completely dead. No "click" or anything. none of the power options work at all. I checked the connections at the battery and they were tight. I tried a volt meter and got a reading of .48. Normally eveything works on this car except the drivers side seat heater.
Prior to me purchasing this car it was owned by a gentelman in his 90's so it wasn't driven much. The battery shows it was new in 2013.
Is this simply a bad battery or before I buy a new one, is there something else I should look at?
Impala77 is offline
post #2 of 8 (permalink) Old 02-19-2016, 11:01 AM
angelo's Avatar
If you can jump start it with another car, then new battery may be in your future.
-ALF out...
angelo is offline
post #3 of 8 (permalink) Old 02-19-2016, 01:35 PM Thread Starter
The car started when we hooked it up to another car. That's when I noticed that i left the interior lights on!?!?
Impala77 is offline
post #4 of 8 (permalink) Old 02-19-2016, 02:18 PM
LowMileage91's Avatar
Dead Battery
Same thing happened to my '91 Caprice about a month ago. Dome light left on. 6 year old battery (Will be in April).
Hooked up the charger, noticed the dome light. Still starts and runs fine, but I know a new battery is in the near future.
LowMileage91 is offline
post #5 of 8 (permalink) Old 02-20-2016, 05:10 PM
shudahadaV8's Avatar
Do this once or twice while the battery is new ... no worries. Best way to charge a battery when that happens (totally zero dead) is to use a smaller 2-4 Amp charger and let it charge overnight. The alternator (though it has a current limiter) can really dump a lot of current into a totally dead battery. This can overheat the plates and warp them.
shudahadaV8 is offline
post #6 of 8 (permalink) Old 02-21-2016, 07:33 AM
Charger
The charger I used showed 2-3 amps on the meter, and took most of the day to charger.
I didn't want to use my wife's new car to jump start, and I wasn't going to ask anyone. Being retired gives us the option to take our time. Didn't need my car immediately.
post #7 of 8 (permalink) Old 02-21-2016, 10:55 PM
A fully charged car battery has somewhere between 25 and 40 Amp-hours of "capacity" in it. That's not to be confused with the cold cranking amps (CCA). As such, at 2-4 amps of charging current, it would indeed take about a day to fully charge it. Yep.
post #8 of 8 (permalink) Old 04-15-2016, 10:59 PM
minimalFEAR's Avatar
some time ago my adult daughter and her two kids (age 7 and 9) moved in with us. My SS is my prime time daily driver, and the kids often come along where ever I go. Don't you know the little ones have to touch anything they see and on more than one occasion switched on the back interior light. Being daylight I never noticed it . . .until - click
nothing!
KIDS
solved the problem by purchasing a minivan and banning the little ones from SS transport!
minimalFEAR is offline
