Climate control and some dash lights out - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 04-10-2016, 02:15 PM Thread Starter
Dhealy3154's Avatar
My hvac knobs and dash lights are out...
Any ideas??? Which fuses could it be?
Or did I cook a resister in the instrument panel???
Dhealy3154 is offline
post #2 of 5 (permalink) Old 01-17-2017, 05:20 AM
Did you find out what this problem was? I have the exact same issue.
Iamduval is offline
post #3 of 5 (permalink) Old 01-17-2017, 05:45 AM
If all that is out and the fuse is good, I would be leaning toward a bad ground. Check the connections behind the kick panel and may as well clean them up while you're there.
http://www.goldsswagon.com/diagrams/...lumination.pdf
This area is known to cause issues with electrical stuff in the car and is easy enough to check.
post #4 of 5 (permalink) Old 01-17-2017, 06:39 AM
The same fuse operates a lot of other lights as well. If those are the only items not lit, then it is a ground, or splice. If your car is a Caprice, it may be the dimmer switch for the cabin. Your ashtray lamp is also controlled by the same circuit.
post #5 of 5 (permalink) Old 01-22-2017, 09:31 PM
Jimpala95's Avatar
Could be twilight sentinal issue.
Jimpala95 is offline
