cant find my remote lock wire - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 05-18-2016, 09:17 PM Thread Starter
iowaSSfan's Avatar
Ok, so my 91 OCC has the AUO on the SPID and I found the box but cannot find the wire to short and learn the remotes. I unwrapped the entire harness from behind the driver taillight all the way to the box itself and nothing. Just for ****s and giggles I pulled the spare tire cover off and did find a single wire plug over there loose. I tried shorting it but no cycle from the locks so not sure what that one is for. Any ideas?
iowaSSfan is offline
post #2 of 7 (permalink) Old 05-18-2016, 09:45 PM
schlicky13's Avatar
On my 94 Fleetwood, it was behind the carpet in the left (driver) rear wheel well area. I pulled down the carpet and it was just hanging there right in front of me, couldn't miss it. Obviously your car is technically a different generation (pre-LT1), and I also just realized you're dealing with a wagon so I don't know if they changed locations at some point or not. If no one else comes up with a definitive answer before tomorrow, I can take a picture of where mine is sometime tomorrow if it would help.
Something witty.
schlicky13 is offline
post #3 of 7 (permalink) Old 05-19-2016, 09:54 AM
Z09B4U's Avatar
Location? Location? Location?
From my 1994 FSM for wagon: "Clipped to rear header harness, on LH "D" pillar"
Search the forum for the keyless entry programing plug. (other words may work better) to find a picture. GM probably used the same plug for many years.
Z09B4U
Z09B4U is offline
post #4 of 7 (permalink) Old 05-23-2016, 02:48 PM
cardude720's Avatar
Mine was in the D pillar. See pic in this thread:
https://www.impalassforum.com/vBullet...-remote-2.html
Home Plate/1st Base Delete, Swiss Cheese Airbox, PCM4Less Tune, Rear: Bilstein
F4-BE5-E250-M0/Moog 173lb #5419, Impala SS rear end: Posi/3:73/discs, US MAG Ramblers 20x8/9.5 255/45 - 275/45, Front: Bilstein 24-011044/Wilwoods, F/R SS Brake Lines, front Hotchkis Sway
cardude720 is offline
post #5 of 7 (permalink) Old 05-27-2016, 12:24 PM
CapriceCarl's Avatar
Mine was right there where your photos showed.
'92 OCC 305/LO3 @ 243k
CapriceCarl is offline
post #6 of 7 (permalink) Old 05-28-2016, 10:05 PM
The '92 Olds Custom Cruiser service manual shows the programming connector behind the right side back body pillar post. "Remove right side back body trim panel to access programming connector". I had the reverse problem, I searched for it on the right side like the manual says in my '92 and it was behind the left trim panel by the taillight. They changed it at some time and it didn't get in the manual I would guess.
Allan H. is offline
post #7 of 7 (permalink) Old 06-15-2016, 11:34 AM
jetfire88's Avatar
All my '91 OCC's have it behind the Right D-pillar (accessible by removing spare cover), all the '92's are behind the Left D-pillar (accessible by removing cubbyhole panel).
Jim Morris
866 South 75th Street
West Allis, Wisconsin 53214-3013 USA
414-774-8898, [email protected]
'91 OCC daily driver,
'92 OCC, Hurst Olds wannabee,
'92 OCC #4344 of 4347
jetfire88 is offline
