Interior Lights - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 06-19-2016, 07:52 PM Thread Starter
Interior Lights
The interior lights on my '96 do not turn on when any door is open. They do work with the dimmer switch. It looks like the wires are connected to the drivers door switch. Where should I look first?
BTW, I thought it may be the dimmer switch so I swapped it with another one I had and had the same issue.
Jesse Walter is offline
post #2 of 6 (permalink) Old 06-19-2016, 08:16 PM
Start with a description of your car. If it's a 9c1, it makes a difference.
Jim B.
fbi9c1 is offline
post #3 of 6 (permalink) Old 06-20-2016, 03:57 PM Thread Starter
This is for my '96 Impala SS.
BUT....The lights in my 9C1 don't work with the door either...lol
post #4 of 6 (permalink) Old 06-20-2016, 05:53 PM
Dillon's Avatar
I am having the same issue as well, I drive a 94 9C1. The dimmer switch turns them on and the remote lock turns them on for a little while, but not opening the doors.
Like Driving On A Cloud
Dillon is offline
post #5 of 6 (permalink) Old 06-20-2016, 06:25 PM
9c1's are made that way intentionally. If you want them to work with the doors, you will have to remove the plunger switches for each door and fish around in the hole for the wires which in most cars are in there with tape over the wire ends. When you fish the wire out, hook it up to the switch and it will work. This will require some patience
Jim B.
fbi9c1 is offline
post #6 of 6 (permalink) Old 06-20-2016, 07:28 PM Thread Starter
Very good info! I will check my impala too. Maybe someone remove the wires on that one also.
