Connector ID - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 06-28-2016, 09:42 PM Thread Starter
boofers's Avatar
Connector ID
Looking to see if anyone here knows where this plugs into? its on the wire loom for the A/C recharger. Here's a pic
1996 BBB, 396ci Golen LT4, Yank 3600, TransGo shift kit, 3.73s, P71 MMC driveshaft, CIA Tri-Y Gen II, X-Pipe, Dynomax UltraFlo exhaust, Hotchkis Sway bars & Springs, Bilstein Shocks, UMI extended control arms, ODBI conversion, all installed and tuned by Mike Harris
boofers is offline
post #2 of 5 (permalink) Old 06-28-2016, 09:51 PM
ocala's Avatar
Could that be the fuel pump test lead?
ocala is offline
post #3 of 5 (permalink) Old 06-28-2016, 10:01 PM
Jimpala95's Avatar
Fuel pump test lead.
Jimpala95 is offline
post #4 of 5 (permalink) Old 06-29-2016, 07:36 AM Thread Starter
boofers's Avatar
Gotcha, was trying to diagnose my A/C and thought that was related to it. Thanks all
boofers is offline
post #5 of 5 (permalink) Old 06-29-2016, 07:57 AM
Yes, that Wire with 12V applied to it will override the Relay/Prime Circuit of the Fuel Pump. This is helpful for testing Fuel Pump issues as it will force the pump to run continuously instead of the 2 second only prime without Oil Pressure. See link below
https://www.impalassforum.com/vBullet...lp-please.html
