Group 48 battery - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 08-18-2016, 07:59 PM Thread Starter
Group 48 battery
My Tahoe has a group 48 battery, with top posts. Very easy to use the top post clamps GM designed for the 1500 series trucks. A lot of contact area. Much much better connection that our cars, with the old side terminal bolts, that are difficult with work with, and are supsetable to over tightening. If someone came up with a cable kit, I would definitely upgrade to the new top post design.
94 + 95 + 96 = 3
the blur is offline
post #2 of 3 (permalink) Old 08-18-2016, 08:08 PM
ocala's Avatar
http://innovativewiring.com/?page_id=175
You're welcome!
ocala is offline
post #3 of 3 (permalink) Old 08-19-2016, 07:17 AM
gbhs72's Avatar
Battery
Might want to check this one out. Leaves plenty of options. Super Start Platinum 34/78PLT - Battery | O'Reilly Auto Parts
Another thing to consider is using Military terminals and then you don't have to change cables.
Mark: Snowman-33
gbhs72 is offline
