Clear Headlight Install Help...plz - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 08-19-2016, 04:35 PM Thread Starter
Question Clear Headlight Install Help...plz
Anybody have instructions or a video on how to do install clear headlamps? They're appearing to be a little more than "plug'n'play" and I could use some assistance plz.
Thx, Rob
Robert Keeler
Tampa, FL
[email protected]
1996 Dark Cherry Metallic Impala SS, 50,000 miles, Tri-Y headers (minus cats), Flowmaster Mufflers, Sequential Tail-lights, Complete Trunk Kit, 160 Degree Hypertech T-Stat, OBD-1 PCM by Bryan Herter, SSRI Intake, 3.73 Gears.
96 Pala is offline
post #2 of 7 (permalink) Old 08-19-2016, 05:21 PM
And no fair saying, "Mine"
Whose 'clear headlamps' we talking about there eh? FocuzTech? Some other brand?
post #3 of 7 (permalink) Old 08-19-2016, 11:56 PM
KoolAidMan's Avatar
I just changed mine about a month ago and it makes a big difference in more than 1 way.. Don't have much pics but for starters you definitely have to take off the corner lights first. There is one screw on top,from inside the hood of course, holding it in then it should be able to slide out forward. Then it's just a few 10mm bolts holding the actual headlight lense. It's 2 on the side close to the hood latch and then about 2 or 3 behind the the corner lenses. Which is why u have to remove those first. Shouldn't take longer than 20-25 min even for a novice. And of course, don't forget to unplug all the bulbs which should all twist out.
95' 9c1 Caprice - DD - 250k Stock trans, and was still burning rubber in 1st and 2nd
94' 9c1 Caprice - RIP 2014 - 90,000 original miles TOTALED ..and thanks to this beast, walked out with a scratch
CIA Gen II Tri-Ys and Hi flow cats, CAI, SLP Air Foil, Flowmaster mufflers(for now), TransGo HD2, Detriot TrueTrac w/ 3.08, Bilsteins all corners, H&R Lowering Springs, Moog Steering, Stealth Brake And Bolt II Mod, TB bypass, 160 TS, 6K 35W HID, PCMPerformance 91 Tune and more to come..
KoolAidMan is offline
post #4 of 7 (permalink) Old 08-20-2016, 12:01 AM
KoolAidMan's Avatar
Oh and don't bother with the star looking bolts (torx). They just adjust the light beam direction. you don't even need to touch those to remove the headlight
post #5 of 7 (permalink) Old 08-20-2016, 10:33 AM Thread Starter
Thx guys...with your help and a little patience, I figured it out...although for whatever reason the passenger side capsule is looser than the driver's side and i'm struggling to find where it's loose at...
Robert Keeler
Tampa, FL
[email protected]
96 Pala is offline
post #6 of 7 (permalink) Old 08-20-2016, 06:33 PM
KoolAidMan's Avatar
There's 2 bolts behind da corner lense and 1 on top. Make sure to get the one on top and just tighten everything up. Mine were a little loose too and when I double checked, I was missing one of bolts on top from the inside of the corner lense that holds da headlight in place as well
post #7 of 7 (permalink) Old 08-21-2016, 04:01 PM
KoolAidMan's Avatar
This is the bolt I'm talking about that's behind da corner light. Not the Philips screw but the one right if it that's upside down, hence why u have to remove the corner light first.. Just as reference. And the Philips screw is the one holding the corner light in.. Incase any1 else is wondering
